It happens that I have on hand NIP buggy dampers,
DT03 damper set
CVA buggy damper set
DF03 Alloy damper set
Aeration buggy dampers
TRF big bore Aeration Dampers
Egress Hicap Dampers
what I was thinking was doing a comparison thread, but I’m not sure where to put it on the forum where it’ll be the most help.
Ideas?
Juls
32 minutes ago, Jonathon Gillham said:
What about thay build sub-forum? A comparison on shock types would be a sticky thread right?
This please, would be a great source of info. Never seen a proper direct comparison 😁
Yeah, I figure general will have more initial exposure, my concern with some other areas not many people would find it (not that, that would really matter)
im wondering if I shouldn’t pickup a few of the common aftermarket sets to add in there, like yeah racing/3racing sets??? Maybe not.. have to wait longer then.
Instead of the aftermarket, there should bee the sleeved dampers from the Dyna Storm. That´s a significant step for Tamiya dampers, too.
Well believe it or not I can actually do that.... but they are re re ones, not sure how different they where.
how far do we go here though, I can’t easily get my hands on a DF02 alloy shock set, so that will be missing plus any of the other sets that are discontinued and not readily available nip.
How do you plan/want to do the comparisons? What are you actually comparing and what tests if any are going to be a part of the process?
Assuming an easily replicated by others process how about deciding a set process that others can follow and can add to with the shocks that are missing if they own them.
Maybe put up a list of the shocks you’d like to add but don’t own/can’t get.
I’ll be purely comparing construction/dimensions, as I’ve use most before many of the optional shocks Ive found have vastly different dimensions to the original kit dampers.
I suppose I’ll make some observations about my thoughts of how something might be better than another.
