Collin 1956 Posted February 15, 2019 I put this in a new topic because seems like no one is seein ig inside my Dyna Blaster topic... Dyna Blaster/Storm/TR15-T have a 3-gear transmission with a inner ration 2.0, is this correct?. Now I have spur gear 84 and pinion 23 which does make FDR 7,3. I run a Nosram 10,5 brushless, which regards FDR 8.0 for buggys and FDR 9.0 for trucks. Now I need larger spur gears because I cant put the motor closer towards. Or need to fit a very large pinion gear? But then FDR goes lower... Anyone can point me to a good setting for starting? Share this post Link to post Share on other sites
ThunderDragonCy 7881 Posted February 15, 2019 If you still have 0.5mod gears I think you will struggle. If you can somehow convert it to 48dp the DB01 runs a 91t spur gear. Part is a bit 51314 but you will need the Tamiya octagon shape clutch pads. Share this post Link to post Share on other sites
Collin 1956 Posted February 15, 2019 hmm.. on my Losi I am running it only with 0,6modul and its fine. I´ll just find out what to do... Share this post Link to post Share on other sites
