Hi
I have a Flysky fs-i6s transmitter with a  ia10b receiver and when I use channel six weather by switch, button or stick, channel seven also operates but when channel seven gets used only that channel works. Any help on fixes would be much appreciated thank you.
Sounds like you have a mix active on your transmitter. Turning it off ought to rectify the issue. Not familiar with the menu, so can't tell you where to do so unfortunately.
thanks TurnipJF found the mix screen and it is off, Ive only got this problem with the flysky receiver my turnigy receiver doesnt have this issue and its exactly the same just branded with a different name.
I did a factory reset of the transmitter and reinstalled the firmware update again, bound the flysky 10 channel and 6 channel receivers to the transmitter with no trouble, must have been a gremlin in the system somewhere and scared it off with the reset
