Sign in to follow this
joeling
Lancer DF-01 build
Just spent the weekend building this kit acquired a while ago. Stickers took a lot of time. Wheels / tires are Tamiya 2.2" and Pro-Line Dirt Hawgs.
B938D77F-58AC-4EB7-9C8E-0AC5FB7823AC_zps
Front end
E5AE8800-B529-4A35-9D2F-A92F32762613_zps
rear end
2C67CE81-1CD0-429D-8367-D019295D43E1_zps
completed kit
D20C3770-4DC1-41BA-9389-B520CB4EA8C7_zps
1B85FF0B-321D-4757-B12A-92BB863B7AFD_zps
Getting for painting
5647748E-93C9-4FD4-AAC4-27C28C54419B_zps
Body in progress
0E443A66-C005-49EC-BF79-928B5269982E_zps
C13B8F20-491D-42D4-A242-8463BE7C9946_zps
Stickers in progress
71B5FC23-F652-46BC-85D9-FED74D184B12_zps
8FB3D2E6-CC47-4561-AEEF-8FBBECC5AF7E_zps
D7026E49-B3E6-4F7B-A37F-3F90AFB72911_zps
F58BAC1F-1988-4349-8613-F2CB987911D0_zps
Nearly done.
  • Like 11
I had this model a few years back. Brilliant fun on all surfaces.
16 minutes ago, Juls1 said:
What is the wheelbase set at for this body?
Pretty sure they are 267mm like the Manta Ray et al. Should have been called the TA01L to avoid confusion with the proper buggy in my opinion. It's a TA01 with the rear arms flipped backwards instead of swept forwards.
That one does look great. Especially with the buggy wheels.
Still working on the light bucket / mirror etc. Hopefully, painting can be completed tomorrow. Then I can get started on fixing up the LED lightings.
These are built the same as the 58154 M0125 Hummer. They have a 280mm wheelbase and use 2-piece lower arms that are specific to this chassis. The rear end employs a "wide" version of TA02 rear arms, which requires the longer 42mm driveshafts. The front arms are the exact same dimensions as the TA02, but use TA01/DF01 knuckles to match the wider track of the rear, and also uses 42mm shafts. This is all tied together with the longer DF01/TA01 chassis tub, which is why you end up with a wheelbase that is longer than that of the Manta Ray and Top Force buggies.
It's also why you can fit taller/wider tires on these models. I'd say it looks like fun 😎
Maybe it should be called the TA01T?
Managed to install the light buckets and LEDs
AED0C3A8-4205-4D21-9E22-7086B08A29F9_zps
3D7ABDDF-C009-48F6-8E28-FCD9BA974AB8_zps
A5EB87A3-6350-4A8A-83E1-374A77D7ECDF_zps
26538A55-FC73-4413-8615-2419B5B25E81_zps
870D5A93-08A2-40F4-AB1C-8935146909AE_zps
Do u think these MST crawler tires with original 1.9" wheels look better or the buggy wheel / tire combo ?
As much as I like the usefulness of having bigger tires/wheels on this chassis, those MST tires look great with those wheels B)
The higher sidewall looks far more realistic.
i wish there was 1.55 wheels and rally tires to suit.
Strange proportions, that body. Been looking at this kit for a while, but could never decide wether I like it or not.
Now that I've seen it from this angle, chances are I might actually like it :wacko:
