matman 1499 Posted March 1, 2019 On 2/28/2019 at 8:26 AM, Thommo said: Brushless motors should be fine, just flip the pinion over if you need to. The issue with the Sport Tuned motor is really that the rotor shaft is just a wee bit too short. I have brushless and didn't need to flip the pinion over . Pic of BL and pinion , run well . 1 1 Share this post Link to post Share on other sites
Thommo 1218 Posted March 3, 2019 On 3/1/2019 at 7:38 PM, matman said: And now they are on my Boomerang Thommo .. Ha Ha.... I did notice that too, pictured in another thread ! That Egress has been nut and bolt restored to original parts now. Just need to get a re-re body set for it eventually. 1 1 Share this post Link to post Share on other sites
Hl0107 16 Posted March 4, 2019 hi guys how do I know I adjust the differentials right? Share this post Link to post Share on other sites
Hl0107 16 Posted March 10, 2019 First parts to arrive!! Share this post Link to post Share on other sites
Hl0107 16 Posted March 13, 2019 Hello guys Did the kit bring extra parts? Yesterday I damaged a 2 mm E ring CirClip BC-8. Also here is a photo from last night progress. 1 Share this post Link to post Share on other sites
Rb4276 803 Posted March 14, 2019 On 3/13/2019 at 6:34 AM, Hl0107 said: Hello guys Did the kit bring extra parts? Yesterday I damaged a 2 mm E ring CirClip BC-8. Also here is a photo from last night progress. Looks good so far, i ordered my egress today along with yeah racing aluminum front and rear knuckles 1 Share this post Link to post Share on other sites
Hl0107 16 Posted March 25, 2019 Hi guys. Could this baterry fit the egress? I think for the price I could buy a couple abd change the plugs. Share this post Link to post Share on other sites
Hl0107 16 Posted March 27, 2019 Here is with the wheels, tires and body for bashing around. The original body, wheels and tires are going to be for display only. This is my first painting but Im not very happy with the results. I also need to align the wheels and finish mounting the electrical parts. 4 Share this post Link to post Share on other sites
Rb4276 803 Posted March 27, 2019 18 minutes ago, Hl0107 said: Parts!!! Im putting a 13.5 in my egress too. What size pinions did you go with? I have 17-28 available from my tt02b which has the same pitch. I have read to go lower with a brushless instead of the stock 22 1 Share this post Link to post Share on other sites
Hl0107 16 Posted March 27, 2019 16-22 I think I'm going to tryout first with the 19. I let you know how it goes. Share this post Link to post Share on other sites
Rb4276 803 Posted March 27, 2019 15 minutes ago, Hl0107 said: 16-22 I think I'm going to tryout first with the 19. I let you know how it goes. That is about what i was thinking 1 Share this post Link to post Share on other sites
Thommo 1218 Posted March 27, 2019 2 hours ago, Hl0107 said: Awesome ! From memory, I think those three coloured terminals will twist and pull straight off of the motor if you need to solder the ESC wires straight onto the motor. You may need to do this in order to have the wires clear of the steering servo. Is that a steel pinion ? If not, you definitely want a steel pinion (and less grease) ! 2 Share this post Link to post Share on other sites
Hl0107 16 Posted March 27, 2019 Thanks thommo Im not sure about the material of the pinions. They are tamiya but the label doesnt said anything about the material so im guessing their not steel.🤦🏽♂️ Share this post Link to post Share on other sites
WillyChang 1814 Posted March 27, 2019 Tamiya ones sold in pairs are made from soft silvery cheese. The only T ones that last ok are sold singly and HFC coated, but only come in limited sizes. No need for brand loyalty, I buy pinions by RW or Robinson - you want the "metric 06" range. 1 Share this post Link to post Share on other sites
Hl0107 16 Posted March 27, 2019 😲Got it. I think i would try and see which one is better for the motor and temp and then order a decent one. Thanks again for the heads up. Share this post Link to post Share on other sites
Thommo 1218 Posted March 28, 2019 9 hours ago, Hl0107 said: Thanks thommo Im not sure about the material of the pinions. They are tamiya but the label doesnt said anything about the material so im guessing their not steel.🤦🏽♂️ It looks to be a standard Tamiya AV pinion and unfortunately they are just not suitable for continued use. You can check with a magnet if you're not sure but I'm guessing that one will fail the magnet test. As per Willy's suggestion, you want to get yourself a few mod 06 or metric 06 pinions from either RW or Robinson Racing. The brushless motor will have heaps of torque so I would say you can comfortably start with a 20 tooth pinion. I would get a 20t and a 22t for that set up. 1 Share this post Link to post Share on other sites
Hl0107 16 Posted April 18, 2019 Hello guys, Do you know a good place to order an extra set of decals? Share this post Link to post Share on other sites
WillyChang 1814 Posted April 19, 2019 On 26 March 2019 at 1:22 AM, Hl0107 said: Hi guys. Could this baterry fit the egress? I think for the price I could buy a couple abd change the plugs. wow that's good buying... 1 Share this post Link to post Share on other sites
Mahjik 197 Posted April 19, 2019 6 hours ago, Hl0107 said: Hello guys, Do you know a good place to order an extra set of decals? http://www.pyramidmodels.com/shop/product.php/584/tamiya_egress_1_10th_scale_decal_set 1 Share this post Link to post Share on other sites
Hl0107 16 Posted April 20, 2019 I test the car an the battery runs for about 20 minutes and it runs great. After every run I check the motor and its barely gets warm. I'm running the motor with the 19 pinion. Is this ok? Share this post Link to post Share on other sites
WillyChang 1814 Posted April 21, 2019 6 hours ago, Hl0107 said: I test the car an the battery runs for about 20 minutes and it runs great. After every run I check the motor and its barely gets warm. I'm running the motor with the 19 pinion. Is this ok? Is cool, is good! Means it's running efficiently & not wasting energy to heat. Have got similar ~3000kV combo from SpeedPassion in Avante & Egress, they barely get warm too. They go more than fast enough so haven't bothered trying to gear up. Fan on ESC sounds a bit loud... thinking of disconnecting it if it's not really needed Share this post Link to post Share on other sites
Hl0107 16 Posted April 21, 2019 Thanks WillyChang! Yes, its fast enough with the motor in 0 timing and 19 pinion. I got two fans with the kit and the one with the motor is loud. I think I'm going to try running it without the fan. Share this post Link to post Share on other sites
