lentner3 281 Posted March 1, 2019 Hi all, I’ve just finished my XV-01 long damper spec build and I must say I’m very impressed with the quality of the kit and design. However I do need a body to go on it as this needs to be a runner. I’m Concerned about clearance due to the bigger shock towers and not sure which fit body’s fit apart from the stated compatible evo and Impreza shells. I’m not keen on either of them. what are others using on these that fit well? pictures to follow TIA 1 Share this post Link to post Share on other sites
Superluminal 3729 Posted March 1, 2019 Lancia Delta is first one that springs to mind 1 Share this post Link to post Share on other sites
Juls1 1653 Posted March 1, 2019 Most rally body’s will fit if it’s being run as off road. If you want to run lower profile body’s on the road, the stock towers are included in the box just pickup a set of micro (m chassis) shocks to go on it. You don’t lose much travel over the stock long damper setup. To get the most travel out of the XV01 long damper towers you will need a set of CC01 or GF01 alloy dampers. And a whole pile of grinding and cutting the suspension parts to allow the extra available droop. It needs hard sway bars after that mod or there is too much traction leading to constant rollovers. Share this post Link to post Share on other sites
Blista 1517 Posted March 2, 2019 Not wanting an Evo or Subaru cuts out a large number of rally cars but there's the Toyota Gazoo Racing TRD 86 and Toyota Gazoo Racing WRT. Share this post Link to post Share on other sites
InsaneJim69 1582 Posted March 2, 2019 Yaris WRC is a cool body and quite easy to paint and decal. I chose to do mines in full tarmac spec, but it's just at home with high ground clearance ready for a gravel stage 👍. James. 4 Share this post Link to post Share on other sites
lentner3 281 Posted March 2, 2019 I like the Yaris is it 257mm? Share this post Link to post Share on other sites
Juggular 4914 Posted March 3, 2019 On 3/1/2019 at 2:35 AM, lentner3 said: I’ve just finished my XV-01 long damper spec build and I must say I’m very impressed with the quality of the kit and design. I've got nothing to add except... I envy you, I envy you, I envy you, I envy you, I envy you, I envy you, I envy you, I envy you, I envy you, I envy you, I envy you, I envy you, I envy you, I envy you, lol... looking forward to seeing your pics! 1 1 Share this post Link to post Share on other sites
InsaneJim69 1582 Posted March 3, 2019 13 hours ago, lentner3 said: I like the Yaris is it 257mm? Yes 257mm. James. Share this post Link to post Share on other sites
