lentner3
XV-01 LONG DAMPER SPEC
Hi all, I’ve just finished my XV-01 long damper spec build and I must say I’m very impressed with the quality of the kit and design. However I do need a body to go on it as this needs to be a runner. I’m Concerned about clearance due to the bigger shock towers and not sure which fit body’s fit apart from the stated compatible evo and Impreza shells. I’m not keen on either of them.
what are others using on these that fit well?
pictures to follow
TIA
Most rally body’s will fit if it’s being run as off road. If you want to run lower profile body’s on the road, the stock towers are included in the box just pickup a set of micro (m chassis) shocks to go on it. You don’t lose much travel over the stock long damper setup.
To get the most travel out of the XV01 long damper towers you will need a set of CC01 or GF01 alloy dampers. And a whole pile of grinding and cutting the suspension parts to allow the extra available droop. It needs hard sway bars after that mod or there is too much traction leading to constant rollovers.
Yaris WRC is a cool body and quite easy to paint and decal. I chose to do mines in full tarmac spec, but it's just at home with high ground clearance ready for a gravel stage 👍.
James.
I've got nothing to add except...
I envy you, I envy you, I envy you, I envy you, I envy you, I envy you, I envy you, I envy you, I envy you, I envy you, I envy you, I envy you, I envy you, I envy you, lol...
looking forward to seeing your pics!
13 hours ago, lentner3 said:
I like the Yaris is it 257mm?
Yes 257mm.
James.
