Hi there,
I decided to build a replica of my VW bus, a 1973 lifted type2 bay window (with a water cooled v6 engine ) into a RC model.
I purchased a reedition 2010 Sand scorcher and started the build couple month ago,
I thought it would be all about the details, trying to replicate all the work that went into my original bus into a 1/10 scale version, using a mix of old models parts, 3D printed parts and so on...
This is where things started to be a little more tricky than I thought, the only body I could find online of a type 2 bus 1/10 (the one with the square front, not with the V front) is an ABS Body and a Lexan body found on eBay that are basically vacuum molded and lack a lot of details as a result .
Second huge detail is the wheel spacing, the bus front to back wheel distance Of the bus body is a lot smaller than the sand scorcher wheel distance... this is when I decided to cut the bottom plate and reduce the overall size of my Sand scorcher body :/
In this thread i’ll Show you all the steps of my work in progress, this is far from being done but i’m Planning on posting regular updates of my built .
Hopefully this will be a good one . Here are some pictures of my (real) Bus , you can find more here
http://www.instagram.com/pacifist_northwest
. Let’s see how close I can get :) wish me luck.
Step 1: building the sand scorcher
This part was all fun, to be honest the last tamiya model I built was 17 years ago , a ford escort 4x4 (I still have it, will post pix later)
building the scorcher is pretty straight forward, I love the quality of the built , metal parts, feel solid and strong .
Step 2: when you realize the bus body is too short for the sand scorcher bottom plate ..
As you can see in the picture , the bus body (distance front to back wheel) is shorter than the original scorcher... 2 ways to deal with it, 3D print a new plate or cut and re-drill  the plate .. let’s cut it!yRQe1vDJ_CWzZGUWVQXwMOeWMKvBoWqmXXLCevBz
using a metal scissor , curing the plate was easy, but this is where things started to get messy ..uUq9q0ghI3ZxBIUrFGkW3Ruh0sP-Gb4ygp_3udK-
drilling the mounting hole back in place
3Kc6gHsdFBHM6vb3YpvPRJs2B1RMxmCUdjZbeB4n
VRX8cXVYk7tIDbllsb48aRYlLORn7-gLuX46zP7i
mounting back the plate
-the original box barely fit in there and I made sure the steering component will have free range of motion .(notice the plastic box is really close to the steering component ) I basically got rid of the extra front box )
XD028E8zQBglA5M9v8T1mIsuBa--w56aC8CHHucV
MaqvZ9Gjk7Sk6kbB7sbE_k-aZAhFBus1wJhf-y7M
et voilà , wheel distance fits the new body... now will everything fit , works well.. not sure :)  time to experiment .
On 3/5/2019 at 8:24 PM, Bnkolate said:
By the way, is it the right part of the forum to post this kind of build ??
Might suit the Builds forum a little better. I doubt this forum gets much traffic. Message the moderator and ask for it to be moved.
Step 3: Houston we are running out of space for components ..
well, after all that cutting etc , I wanted to make sure things will fit inside, the main issue was the steering component geometry, a pretty long rod that would basically push the directional servo to the back of the box, eating up most of the space for battery , receiver etc .. zTTDV9SoC8RDi7pqYXBBstf9VHOZdQJvMG7pwBGi
this is where I decided to place the servo elsewhere, could it fit between the front wheels , mmmh yeah indeed, very thought but why not . This is when I decided to get rid of the original direction mechanism and build a new one .
sm_VNL88Uo5Qj5kbHWpqbdNHoVGKATlPiO5NpQn3
Then i took the front part of the box and rotated it 90 degree to protect the servo, things start to make sense (in my opinion) now I need to secure all that and make sure there is clearance for everything, it’s going to be tight .
poq8SfomPbxdhZDKfQX5dh-6B1SOBlLyagQ9gvYL
A part of the box had to go to leave some space for the rods , oh well this is going to Be interesting :)
k_FbKWtFQyArQJ4aXFWdWw4wgLRBCO0A6hvHN1FR
Step 4 -how will the body attach to the frame ??!
this is where things start to get messy, sorry about destroying the beetle body but I needed to come up with a plan and “recycle most of the body to make this plan possible .
I started to cut the body to see how the wheel arches will be placed
lQGY3UMtwW155vUbdPG0pThoJvZvoWp239xxiLrp
in the following picture you can clearly see the size difference between the original beetle body and the new chassis .
yUO4xscSCwNKiAAliHOq6KuGAiHCpCzZkPSt_hZS
In order to fit the bus body around the wheel arches, some necessary trimming is achieved
BXQEv8CRN8zhMZcG0V-ciB5SOHYm297qAvD6WUaQ
my goal is to reuse the wheels arches combined with wheels arches guards to define the final placement of the bus body .
fw0tjv4_sXnhQToYvPF-rhEBIrnErQhM3A44Eu7Y
M2PRmXc7uVlh07B796my5ouGf8G4s_RPzlq_N0rI
i used a translucent shell to make sure everything will fit correctly for the rest of the build, i’m Keeping the ABS one on the side to make the final body .
This allows me to mark, see the fit, imagine the mounting points etc
Dasj1nIHKsz6nBH2Z9yGgRj5z8VWKDBIFzmPYNdy
n-W-Msxtst51XPXXvbV-ErIkwYSxjK7lm9j-2sCO
things start to take shape ... still don’t know how I will fix the bus body to the plate though :)
Your 1:1 is an absolute beauty - i’ve always prefered the bay windows and particularly the T3s over the splitties. Maybe i’m a philistine though.
This is going to look great when it’s done. I’m subscribed
