Fabia130vRS 2098 Posted March 14, 2019 So I am a new owner of a stock FF03 chassis. The only upgrades I have notices so far are Motor pinion and Spur. with 45T steel pinion and 85T spur in 48P. Internal ratio is 2,6, + 1,88 = 4,48 On my TBLM 8T with a TBLE1 ESC, that is 4750kV on 2s. Nice and fast pretty stable on the track where we drive, not your daily asphalt you are used to. I got the car setup as it is now. My idea was to upgrade the fron of the car... a 54471 Tamiya Steel Gear Differential Unit 54398 Tamiya FF-03 Gear Case (For Gear Differential) I dont have any idea what kind of diff oil should I use here? lets say conditions with medium to high grip... ? Next idea was... I am not a fan of the 3 racing carbon conversion, the blue bling bling can be left out. So making the whole chassis carbon reinforced with the standard turnbuckles and some carbon parts that are available from tamiya, like the rear shock tower... do the black big bore shocks fit on these? like a FF03 black edition I you can imagine what I mean. A stock carbon reinforced chassis with gear differential? part numbers? Share this post Link to post Share on other sites
Butler 338 Posted March 14, 2019 (edited) FF03R Gearbox cases allow you to run the TA06 gear diff, if you can find them. I had that on my other FF03. I didnt upgrade anything else, it never felt it needed it and that was after a lot of laps at a asphalt track. (other than a rear wing). There is a huge FF03 thread on rctech. Loads people had issue with the ball diff. I never did. Edited March 14, 2019 by Butler Sorry missed the middle text, I see you're already on it. 1 Share this post Link to post Share on other sites
Juls1 1661 Posted March 14, 2019 The carbon reinforced chassis is stiffer than the stock chassis but not heaps stiffer, anything that stiffens up the chassis/suspension will typically reduce grip on rough surfaces. Typically we stiffen chassis parts on high grip tracks to allow more obvious tuning changes. There is lots of things you can upgrade on the chassis, removing slop from the front suspension seemed like a no brainer for me. Share this post Link to post Share on other sites
Nicadraus 6198 Posted March 14, 2019 I noticed that the tub chassis flexes a bit in its rear part. So i created a stiffener using a 2mm CF board (which I actually copied from the Tamiya 54264). 3Racing also has their own version. I'm working on my slow build with my FF03. Haven't ran it yet as I am still waiting for a few more parts to complete the build I want to achieve. Anyway, some other parts I would like to suggest are: - CF rear shock tower - aluminum motor plate - a nice set of adjustable aluminum shocks - universal shafts (I'm still waiting for mine) Here's my kit's current state. Some parts may not be necessary to change but I love the bling. The ESC and servo CF trays are also fabricated. While many of the parts installed are mixed of Tamiya & 3Racing. 4 Share this post Link to post Share on other sites
TurnipJF 9192 Posted March 14, 2019 I found my one behaves brilliantly in almost stock form. The only points at which I deviated from the instructions were with the steering rack and suspension bellcranks which I fitted with ballraces instead of the stock bushings, some shims to reduce play in the aforementioned assemblies and some clamping metal wheel hexes. I have also heard of people having problems with the ball diff, but after being built carefully and tightened appropriately, it has given me no issues at all. 1 Share this post Link to post Share on other sites
Fabia130vRS 2098 Posted March 14, 2019 I try to run my cars only on this green surface. so stiffening the chassis would be a thing to do. so to take out all the slop will help? I thought to order some aluminium spacers from tamiya the 5.5 set. so steering rack and rocker arms are fine carbon reinforced no need to spend on aluminium? I want to keep it light as possible and possible replace the chassis with the carbon reinforced one. Also gear diff, would be a choice to have less maintenance (??), and to get more familiar with gear oil diff as most new chassis use those. Share this post Link to post Share on other sites
Fabia130vRS 2098 Posted March 14, 2019 1 hour ago, Nicadraus said: I noticed that the tub chassis flexes a bit in its rear part. So i created a stiffener using a 2mm CF board (which I actually copied from the Tamiya 54264). 3Racing also has their own version. I'm working on my slow build with my FF03. Haven't ran it yet as I am still waiting for a few more parts to complete the build I want to achieve. Anyway, some other parts I would like to suggest are: - CF rear shock tower - aluminum motor plate - a nice set of adjustable aluminum shocks - universal shafts (I'm still waiting for mine) Here's my kit's current state. Some parts may not be necessary to change but I love the bling. The ESC and servo CF trays are also fabricated. While many of the parts installed are mixed of Tamiya & 3Racing. I am following your build. I think it was exactly your build that lighted my fire for a FF03 again last year. then I have orderd for a friend a FF03 with a skyrc ARES 5.5T mod motor... after he finished building his stock FF03... it was just a question of time. I would like to include the stock motor mount with blue heat sinks. otherwise, carbon reinforced partf, CF rear tower, CF front bumper support, CF servo plate, aluminium servo holders. not sure what shocks should I fit on this car? Share this post Link to post Share on other sites
Fabia130vRS 2098 Posted March 14, 2019 like this. Tamiya (#54031) TA05-IFS Carbon Rein (F Parts) Tamiya Steel Gear Differential Unit Rear TA06 TA06 PRO FF-03R XV-01 #54471 Tamiya FF-03 Gear Case (For Gear Differential) #54398 Tamiya TRF418 C Parts Carbon Reinforced Front Uprights #54568 Tamiya TRF418 E Parts Carbon Reinforced Rear Uprights #54570 Tamiya (#54290) FF-03 Carbon Reinforced M Parts (Damper Stay) Tamiya (#54297) FF-03 Carbon Reinforced Lower Deck plus carbon damper support and carbon servo plate, also rocker arms and steering could possible ball raced allready. only some dampers missing 1 Share this post Link to post Share on other sites
MICHAELs TopForce17 586 Posted March 14, 2019 few others you may need like the stabilizer set and carbon motor mount... https://www.rcjaz.com/tamiya-54259-rc-ff03-carbon-motor-stay-p-90023226.html https://www.rcjaz.com/tamiya-54258-rc-ff03-carbon-damper-stay-rear-p-90023225.html https://www.rcjaz.com/tamiya-54264-rc-ff03-carbon-stiffener-rear-p-90023419.html https://www.rcjaz.com/tamiya-53827-stabilizer-rod-stopper-p-4965.html https://www.rcjaz.com/tamiya-54230-rc-ff03-stabilizer-set-frontrear-p-90018878.html 1 Share this post Link to post Share on other sites
Nicadraus 6198 Posted March 15, 2019 11 hours ago, Fabia130vRS said: like this. Tamiya (#54290) FF-03 Carbon Reinforced M Parts (Damper Stay) Get the 3Racing carbon fiber rear shock tower and you will skip this ^^^ part. The damper stay is aluminum and the CF shock tower has many adjustable options. Here: 3Racing FF03 carbon fiber rear shock tower I heard that the Yeah Racing dampers perform and are more durable than the 3Racing. But if budget isn't a problem, then go for TRF dampers. The best there is. Yeah Racing 55mm aluminum dampers 3Racing FF03 55mm aluminum dampers Tamiya (#42102) 55mm TRF Special Damper Set (Hard BK) Tamiya TRF Aluminum Big Bore Damper 4pcs #42287 Other than that, there are many cheaper hop up parts for this kit from 3Racing and Yeah Racing for about 50% more or less than the cost of original Tamiya parts. 1 Share this post Link to post Share on other sites
TurnipJF 9192 Posted March 15, 2019 Having recently fitted a set to my M-07 I can confirm that the Yeah Racing dampers are very good for the money. Quality of finish is not quite TRF standard but it is very close, and in terms of smoothness I can tell no difference at all between them and TRFs. 1 Share this post Link to post Share on other sites
Fabia130vRS 2098 Posted March 15, 2019 55 minutes ago, TurnipJF said: Having recently fitted a set to my M-07 I can confirm that the Yeah Racing dampers are very good for the money. Quality of finish is not quite TRF standard but it is very close, and in terms of smoothness I can tell no difference at all between them and TRFs. I have the yeah racing ones on my M03. My friend has the 3racing ones, in my opinion they are more smooth then teah racing. but I would probably go for tamiya shocks... would the big bore m chassis shocks fit? 1 hour ago, Nicadraus said: Get the 3Racing carbon fiber rear shock tower and you will skip this ^^^ part. The damper stay is aluminum and the CF shock tower has many adjustable options. Here: 3Racing FF03 carbon fiber rear shock tower I heard that the Yeah Racing dampers perform and are more durable than the 3Racing. But if budget isn't a problem, then go for TRF dampers. The best there is. Yeah Racing 55mm aluminum dampers 3Racing FF03 55mm aluminum dampers Tamiya (#42102) 55mm TRF Special Damper Set (Hard BK) Tamiya TRF Aluminum Big Bore Damper 4pcs #42287 Other than that, there are many cheaper hop up parts for this kit from 3Racing and Yeah Racing for about 50% more or less than the cost of original Tamiya parts. I dont want to use yeah racing or 3racing parts. the carbon reinforced damper stay is front/rear. The 3 racing rear bulkhead is only the rear part. As mentioned, only black and silver is a color here no blue please 1 Share this post Link to post Share on other sites
El Dougo 326 Posted March 15, 2019 I love my FF03 As the others have suggested the gear diff is the essential mod (using 500k oil in mine). I'm part way through a rebuild, new chassis, ceramic bearings, titanium screw kit and lightweight driveshafts. I think your man math for FDR is a little off (spur divided by pinion multiplied by the IDR ratio). I recently made a calculator for my cars, if you want me to change any of the spur numbers let me know and I will post up another sheet. 1 1 Share this post Link to post Share on other sites
Fabia130vRS 2098 Posted March 16, 2019 10 hours ago, El Dougo said: I love my FF03 As the others have suggested the gear diff is the essential mod (using 500k oil in mine). I'm part way through a rebuild, new chassis, ceramic bearings, titanium screw kit and lightweight driveshafts. I think your man math for FDR is a little off (spur divided by pinion multiplied by the IDR ratio). I recently made a calculator for my cars, if you want me to change any of the spur numbers let me know and I will post up another sheet. So 500.000 diff oil? You are right, I thought the internal is 2.0. About 5.0 is the FDR. good idea with the sheets you have made, does it automatically calculate? Share this post Link to post Share on other sites
Fabia130vRS 2098 Posted March 16, 2019 here is a small table of parts I would like to have for the FF03. not sure about m chassis dampers, but everywhere they are talking about short dampers, low rear shock towers... is it something to do or should I stick just with a set of 53571? Share this post Link to post Share on other sites
El Dougo 326 Posted March 16, 2019 Yes 500,000 and It does auto calculate, I would be happy to post a few more if there are any requests from anyone. You want standard size touring car shocks, I run the black coated TRF (same as Nicadraus) that I later added big bore springs to. I would swap out the Carbon reinforced deck and go for a Steering set 54235 and Carbon link 54261. This footage is a little boring but here's mine on the track last summer, I didn't realise at the time that the cross shafts in the diff were broken in half, it still drove awesome as usual 2 Share this post Link to post Share on other sites
