The Chinese ebay rally wherlset I ordered for RR-03Ra has fallen through and I am impatient to progress. I have going to get some tamiya 26mm wheels, but should I also get tamiya rally blocks too, or is there something else better? Do I need foam inserts? Full "on road" newbie here. Educate me please!
Normal tamiya blocks are too hard.
Years ago, we were using tamiyablock copies, which used softer compound. Those were best tires, but they are not available anymore.
However, new Tamiya "Softblock" could be something similar. From first reports, they might have right compound.
As mentioned, I've used both the true tamiya rally blocks and the cheap china knock off and the cheap ones do wear quicker - however it also depends what your running it on. if it's trimmed grass then the cheap ones will be fine. If it;s true rally - IE gravel then I'd suggest (as others have before me ) the true rally blocks, with foam inserts and glued.
