Hi guys.  I have recently reused my Blackfoot 3 shell and repainted for use on an original Blackfoot made up from parts.  So now my wt-01 chassis is naked.  Do you know of any other bodies that will fit this chassis.  It is an awkward long length and even the standard Blackfoot body didn't fit correctly (too short).  Thanks
Hi. I used a ProLine Early 50's Chevy Pickup (part number PL3255-00). I had to cut the arches a bit to avoid the tyres rubbing but otherwise suits the size of the chassis well. I'll see if I can find a pic
I've been thinking about putting the new Hilux bodyset for the CC01 on a WT01.  Being a long wheelbase shell (267mm) it should fit relatively well, it's something a bit different, and it comes with LED light buckets.
New Bright Raptor is same wheelbase as Blackfoot 1 if that helps, I haven't tried it on anything fully but it does line up. It is also a hardbody though the plastic is a bit more flexible.
  • 5 months later...
