TT02R rolling chassis with Hop Ups and what's pictured below. It has some surface scratches on the tub (not deep) but otherwise it's in excellent condition.
Looking for £100 + postage, can add electronics for more cash! see below:
Hop Ups fitted:
Yeah Racing:
Adjustable alloy motor mount
Alloy shocks (with range of springs)
Alloy ball bearing steering
Hex Titanium Screw Kit (approx 8 screws are steel hex and the 4 shock screws are standard Tamiya)
39mm drive shafts (NIP)
3 Racing:
Prop shaft bearing holder
Carbon bumper support (Rear)
Carbon battery brace
Alloy adjustable turnbuckles (steering)
Tamiya:
Carbon Front shock Tower
Carbon Rear shock Tower
High Speed gear set (66 tooth Tamiya spur)
Alloy front bumper support
Alloy differential lock (NIP)
Steel low friction suspension balls
Spare propeller Joints (sealed)
Standard Tamiya R Spec parts:
Alloy prop shaft
Alloy rear hubs (3 degree)
Tamiya drive shafts (front)
Metal shielded ball bearings
Slidelogy 25T alloy servo horn
7.0mm wheel hex (think Team Associated)
20190327_173106 20190327_173117 20190327_173127 20190327_173143
If your looking for more than a rolling chassis I can add and fit a Hobbywing Xerun 120a V2.1 and a 4t Trackstar motor (approx 8000kv) with a cheap servo for more cash.  I can also supply a used body and a good HPI wheel transmitter and receiver that could go with if you want a runner!
