An interesting chassis announced recently by Tamiya: the Lunch Box Mini on the SW-01 chassis. The link is Tamiyablog's; the chassis was also mentioned earlier on this site by TC's Mokei Kagaku, and on his Facebook page.
From Tamiyablog:
Suggested retail price in Japan: approx. ¥ 10600
Expected release date in Japan: July 2019
★ Condensed various mechanisms in a compact new design chassis that fits in both hands of adults
★ Uses an upper arm that works in conjunction with the steering wheel. Reduce the roll of the body at the time of cornering, reduce the fall.
★ The chassis is a gear drive 4WD that transmits the power of the motor located in the center to the front and rear wheels with a gear.
★ The body reproduces the popular Lunch Box in polycarbonate. Adoption of magnet type one-touch body mount makes it easy to attach and remove the body.
★ It can run with four AA batteries.
★ Upgrade to the 4WS (four-wheel steering) specification is possible simply by installing the “Upper Connect Bar (provisional name)” scheduled to be released as an optional part.
As part of the "Star Unit" line, it is likely going to be quite a basic chassis, yet the technical details and the involvement of some sort of Lunch Box might make it intriguing...
Huh... interesting. Or at least, it could be. The price is sure right ($95 as of today's exchange rate), and a new tiny 4WD chassis could be a lot of fun. I'm especially intrigued by the suspension connected to the steering and the easy addition of 4WS. Makes me think that it might be a straight-axle monster/crawler-type design?
Though it occurs to me that Dodge vans are popular for drifting in Japan (no, really). Are we entirely sure that this will be off-road? It could very well be a normal-sized Lunchbox body made of Lexan, on a 4WD on-road drift chassis.
Will be waiting to see how this develops.
Sounds intriguing doesn't it!?
I guess around the same size point as the dancing rider bearing in mind it can be powered by 4 AA cells.
Suspension sounds interesting, like it has sway bars or something? One of the biggest issues with smaller vehicles is roll overs so that sounds like it could be a good little feature.
I guess these means a full size comical Lunchbox is out for the moment? Mind you, I'm not sure how comical it would be to make a more sophisticated and much better handling Lunchbox anyway....
Searching the other star-unit offerings, they all seem to be 1/14 scale. The line about being held in two adult hands boggles me then as the Lunchy is already 1/12.
In the Star Unit series, the buggies are 1/14, the trikes 1/8. Based on the information available about the LB Mini at the moment, I reckon it will be about 1/20 - 1/24 scale.
56852666_1991631147630478_11278243313641
A bit better illustration reveals the size: Racing Truck (MAN/Buggyra) tires on M-chassis VW Beetle wheels. It's really small! Overall length is apparently around 20cm.
(Photo provided by Kentech)
38 minutes ago, Grastens said:
Awwww, it's so cute! :D Thanks for sharing the rendering. But can that be a standard-size servo I see in there?
Yes, a standard servo is supposed to fit.
On 9/8/2018 at 5:53 PM, wolfdogstinkus said:
It looks like Tamiya are on this all ready but bolt on parts to upgrade existing cars. like hex driven portals, C hubs that bolt on existing axles to provide steering options. double wishbone front for lunchbox,  RC kits are being sold for the mini 4wd kits. Tamiya should make their own.
Would like 1/32 mini RC series
Tlt chassis with slight re-design, then all the most popular bodies get shrunk, mini lunchbox, clod, monster beetle, blackfoot.
I do hope it's 1/24th scale. That's the scale I usually model in. It would mean a huge range of body options in proper plastic :P
Kawaiiiii!
Hope the little shell might fit over a TLT too :)
52 minutes ago, WillyChang said:
Kawaiiiii!
I have a TLT, mini lunchy body would be great.
OT, what are some good TLT bodies? I've never really looked.
Me neither :) I only have the truck & SUV... yeah both Tamiya made.
Dunno if there's any TamTechGear shells that might suit, never tried.
Are they m-chassis Beetle wheels with racing truck tyres?  C'mon Tamiya.  Even just a new set of wheels can't be too much to ask.
