graemevw 823 Posted April 14, 2019 About to fit new A parts to my terra scorcher and would like to use e clip hinge pins for the suspension arms. Are there any sets for other cars that have the right sizes? Edit... Looks like the minimum lengths between e clips are 2x21mm 2x22mm 1x45mm 3x47mm Share this post Link to post Share on other sites
taffer 948 Posted April 14, 2019 On my recent new built tshot (in my showroom) i used a mixture of steel shafts, from the tl-01 set and shafts from g6-01 lower arm brace, a Tamiya spacer set was also needed to take up some slop, it came out really well The shafts used in this build came from the following parts.... Tamiya 53301 stainless steel shaft set Tamiya 54695 (used for the inc. 37mm and 52mm stainless steel shafts) Tamiya 53539 spacer set (to remove slop from shafts) unfortunately i didn't make an exact list at the time, I'd have to go back and measure up each shaft! 2 Share this post Link to post Share on other sites
graemevw 823 Posted April 14, 2019 Id have to buy the sets anyway so it doesnt matter if you dont remember which exact ones. Ill go price them up. Thanks. Share this post Link to post Share on other sites
graemevw 823 Posted April 17, 2019 I ended up buying some stainless rod. Ill make a grooving tool for the lathe and make a set of hinge pins. Depending how easy it is to machine all the grooves i may even be able to offer other members custom sets for these cars. All depends how making the grooving tool goes. 1 Share this post Link to post Share on other sites
Peter_B 997 Posted April 17, 2019 On the same subject - anybody done this with a Boomerang? Share this post Link to post Share on other sites
