KitTheRam 11 Posted April 16, 2019 Hey. I have just got a new longer lasting battery (5300, 7.2v) for my grasshopper II. For best results do I charge it out the box or use it till it dies then charge to full? Also, what are the best upgrades for my RC? Any links welcome. Thanks. Kit Share this post Link to post Share on other sites
Mahjik 197 Posted April 16, 2019 I would do a charge before using it the first time. As far as upgrades, start out with a bearing kit like this if you haven't yet: https://www.fasteddybearings.com/tamiya-grasshopper-ii-58043-sealed-bearing-kit 1 Share this post Link to post Share on other sites
KitTheRam 11 Posted April 16, 2019 5 hours ago, Mahjik said: I would do a charge before using it the first time. As far as upgrades, start out with a bearing kit like this if you haven't yet: https://www.fasteddybearings.com/tamiya-grasshopper-ii-58043-sealed-bearing-kit Thanks. Just bought them. Any idea if any aftermarket wheels would fit? Again links welcome! Kit Share this post Link to post Share on other sites
DK308 219 Posted April 16, 2019 5 hours ago, KitTheRam said: Hey. I have just got a new longer lasting battery (5300, 7.2v) for my grasshopper II. For best results do I charge it out the box or use it till it dies then charge to full? Also, what are the best upgrades for my RC? Any links welcome. Thanks. Kit I like to do a slow charge at 0.5C first time with an equally slow discharge rate and let the charger cycle it like that three times. At any rate, you would want your first charge to be straight out of the box at less than 1c. I would just charge @ 2Ah for the first charge on such a NiMH pack. As mentioned,the TFE bearings. The Tamiya ball bearings are not that great. CVA shocks such as: http://www.rcmart.com/tamiya-50519-55mm64mm67mm70mm-mini-shock-unit-p-16274.html?cPath=389_390 http://www.rcmart.com/tamiya-50520-80mm87mm94mm-short-shock-unit-p-8386.html And of course a 540 motor - and ESC fit for a 540 if not already in it. For this you will need a Mod .8 18 tooth pinion gear. Some suggestions for a nice 540 conversion Hobbywing Quicrun WP1060 brushed ESC Absima Thrust B-Spec 21t motor or similar budget minded 21t motors. Pinion. http://www.rcmart.com/robinson-racing-1718-hardened-pitch-absolute-pinion-teeth-p-73422.html?cPath=1293_1519 Note that if you choose to install a 540 motor, it will bolt directly to the gearbox and the motor adapter that sits between the 360 motor and gearbox will not be needed. 1 1 Share this post Link to post Share on other sites
KitTheRam 11 Posted April 16, 2019 48 minutes ago, DK308 said: I like to do a slow charge at 0.5C first time with an equally slow discharge rate and let the charger cycle it like that three times. At any rate, you would want your first charge to be straight out of the box at less than 1c. I would just charge @ 2Ah for the first charge on such a NiMH pack. As mentioned,the TFE bearings. The Tamiya ball bearings are not that great. CVA shocks such as: http://www.rcmart.com/tamiya-50519-55mm64mm67mm70mm-mini-shock-unit-p-16274.html?cPath=389_390 http://www.rcmart.com/tamiya-50520-80mm87mm94mm-short-shock-unit-p-8386.html And of course a 540 motor - and ESC fit for a 540 if not already in it. For this you will need a Mod .8 18 tooth pinion gear. Some suggestions for a nice 540 conversion Hobbywing Quicrun WP1060 brushed ESC Absima Thrust B-Spec 21t motor or similar budget minded 21t motors. Pinion. http://www.rcmart.com/robinson-racing-1718-hardened-pitch-absolute-pinion-teeth-p-73422.html?cPath=1293_1519 Note that if you choose to install a 540 motor, it will bolt directly to the gearbox and the motor adapter that sits between the 360 motor and gearbox will not be needed. Thanks for all the advice. This is my ESC, https://www.wonderlandmodels.com/products/mtroniks-viper-eco27/. Will it work with a 540? Thanks Kit (no news on the wheels?!) Share this post Link to post Share on other sites
TurnipJF 9192 Posted April 16, 2019 The Eco will work with a 27t 540 motor, but would potentially overheat with anything lower. You would have a far wider choice of wheels if you fitted 12mm hex adapters to the rear as the proprietary fitment used by the stock wheels limits your options severely. 1 Share this post Link to post Share on other sites
ThunderDragonCy 7886 Posted April 16, 2019 That ESC will work fine with a 540 27t motor. One of these would be way better than a regular silver can bug much cheaper than a tamiya dirt tuned https://www.modelsport.co.uk/index.php?product_id=428009&gclid=Cj0KCQjw-tXlBRDWARIsAGYQAmccrn3dXSeBibiDkqNdUfpRjjOrQD9uJli2dQ1EqGnhlFE-cfD2ZB0aAp9eEALw_wcB Easiest wheel upgrade is to get Wild One wheels. The Super G version used them. I have them on my GH2. The rear are vintage race 2" diameter so boomerang tyres for general running would be good, but I use 2" size Schumacher mini spike yellow compound with tubby inserts for grass and astro running. The fronts are 2.1" but modern 2.2" slim 2wd tyres work. I use Schumacher cut Stagger. I believe you need the Frog 12mm hex conversion to run anything modern 12mm hex. Front bearing mountibg means you are pretty much stuck with tamiya fronts regardless. 1 Share this post Link to post Share on other sites
KitTheRam 11 Posted April 16, 2019 Thanks everyone. Having a tinker on the kitchen table. This RC stuff is a lot of fun. I got a 5300 battery but it only just fits, so can’t close the hatch properly so rubber banding it - a bit of a bodge but will keep the hatch from coming loose. The bigger battery is wedged in but fine. Share this post Link to post Share on other sites
KitTheRam 11 Posted April 27, 2019 On 4/16/2019 at 9:58 PM, ThunderDragonCy said: That ESC will work fine with a 540 27t motor. One of these would be way better than a regular silver can bug much cheaper than a tamiya dirt tuned https://www.modelsport.co.uk/index.php?product_id=428009&gclid=Cj0KCQjw-tXlBRDWARIsAGYQAmccrn3dXSeBibiDkqNdUfpRjjOrQD9uJli2dQ1EqGnhlFE-cfD2ZB0aAp9eEALw_wcB Easiest wheel upgrade is to get Wild One wheels. The Super G version used them. I have them on my GH2. The rear are vintage race 2" diameter so boomerang tyres for general running would be good, but I use 2" size Schumacher mini spike yellow compound with tubby inserts for grass and astro running. The fronts are 2.1" but modern 2.2" slim 2wd tyres work. I use Schumacher cut Stagger. I believe you need the Frog 12mm hex conversion to run anything modern 12mm hex. Front bearing mountibg means you are pretty much stuck with tamiya fronts regardless. Bought this motor today. Is it plug and play? Or will have to do something to the gearbox first? Also do know if any shocks that will fit that are not black / standard looking? I am going to buy ‘the frog’ hex adapters so I can get some more modern wheels. Thanks Kit Share this post Link to post Share on other sites
ThunderDragonCy 7886 Posted April 27, 2019 19 minutes ago, KitTheRam said: Bought this motor today. Is it plug and play? Or will have to do something to the gearbox first? Also do know if any shocks that will fit that are not black / standard looking? I am going to buy ‘the frog’ hex adapters so I can get some more modern wheels. Thanks Kit Yes, plug it straight into the gearbox with stock pinion and into the ESC leads. There isn't anything off the shelf, but you could buy the DT03 CVA set to get everything you need then get either the Neo Scorcher or Dual Ridge W parts and Y parts. They are the damper bodies and top caps. The neo scorcher versions are yellow, the dual ridge are white. I would suggest getting some really light (I got 10wt) oil for the rear shocks. They don't need much damping because of the live axle. Put the Tamiya oil in the front shocks. 1 Share this post Link to post Share on other sites
DK308 219 Posted April 28, 2019 22 hours ago, KitTheRam said: Bought this motor today. Is it plug and play? Or will have to do something to the gearbox first? Also do know if any shocks that will fit that are not black / standard looking? I am going to buy ‘the frog’ hex adapters so I can get some more modern wheels. Thanks Kit These dampers will work and are made from aluminium. https://tamico.de/navi.php?a=9885&lang=eng When installing the 540 motor, don't use the motor adapter used with the 380 motor. And like I mentioned earlier, you need an 18 tooth 32p/0.8 mod pinion. There is an illustration in the build manual, which shows how a 540 motor is installed. 1 Share this post Link to post Share on other sites
Juggular 4964 Posted April 28, 2019 On 4/27/2019 at 2:32 PM, KitTheRam said: Bought this motor today. Is it plug and play? Yes, if wires came soldered on yours. I have several of those motors (two 23Ts and a 21T). They came with wires unattached. Also make sure you got a 27T motor and not a 21t. (The description says 27t, but the photo shows a 21t) Eco27 can't handle anything less than 27T. If you happened to get a 21T, that's not the end of the world. You could get a Hobbywing Quicrun 1060 ESC. 1060 can handle a greater variety of motors than Eco27. 1 Share this post Link to post Share on other sites
