I’m baffled hoping to find some fresh advice. I have an original Blackfoot, 2005 lunchbox & pumpkin. Recently the pumpkins servo saver comes loose while running it. I’ve changed out the servo. Reset it several times. Trimmed the steering settings on the controller. Doesn’t seem to matter what I do, after a bit I’ve lost the steering, screw is gone and back to the bench. My lunchbox which I built in 2006 has never had this problem. Still runs the original setup. So strange. Any advice? Thanks
Have you still got the small plastic washer in place that fits into the servo saver that the screw passes through and binds on to lock it on to the servo ? .Is the screw the right length and not bottoming out so leaving 'slack' ?
Small plastic washer 🤦‍♂️ That’s a big no. I’ve been scavenging screws the last two times.
