DK308 219 Posted May 26, 2019 My Neo came with the TBLE-02S and CVA shocks. It's a bit of an upgrade that has been added to the kit apparently. Share this post Link to post Share on other sites
Don79 4 Posted May 26, 2019 It was the Nissan that seems to come with the 104. I emailed and asked now but if it does I'll probably get the Neo for 70 euro from Tamico. Share this post Link to post Share on other sites
ThunderDragonCy 7884 Posted May 26, 2019 Big fan of the DT03. Just get some full size car adhesive wheel balance weights off ebay for a few quid and get as many as you can in the front duribg the build (some will go in slots in the front of the tub before you pht them together). Get 50-70 grams around the front, and if you want get some stiffer rear springs (you need around 2.6-2.8lb rate) and some feont tyres aporopriate for the surface you are running it will be sweet! 1 Share this post Link to post Share on other sites
DK308 219 Posted May 26, 2019 If you get a Neo, get a low profile servo. Not a lot of room between body and steering servo. I ha e this in mine. Perfect fit and speed. https://hobbyking.com/en_us/turnigytm-tgy-4409md-ds-mg-servo-9-45kg-0-11sec-44g.html I found that a standard servo will rub on the body, and eventually rub through the paint. Share this post Link to post Share on other sites
Don79 4 Posted May 26, 2019 Thanks for the tips! What about battery size, what fits as far as the DT-03 goes? And is a 17t pinion the pinion of choice with a sports tuned and 2S Lipos? 1 Share this post Link to post Share on other sites
ThunderDragonCy 7884 Posted May 26, 2019 8 minutes ago, Don79 said: Thanks for the tips! What about battery size, what fits as far as the DT-03 goes? And is a 17t pinion the pinion of choice with a sports tuned and 2S Lipos? Pretty much any battery fits. I have a 5300mah square Lipo which goes in no problems. Not sure on gearing for sports tuned Share this post Link to post Share on other sites
DK308 219 Posted May 26, 2019 1 hour ago, Don79 said: Thanks for the tips! What about battery size, what fits as far as the DT-03 goes? And is a 17t pinion the pinion of choice with a sports tuned and 2S Lipos? I'd say anything smaller than 145x50x28mm fits. I have run the Gens Ace 3S 5200 mah packs in mine and they fit perfectly. It's a pretty big compartment. 19t should not pose a problem. I ran a 17 tooth with a 17 turn motor in grass. You can just order a set and see what you like the best. Pinions are fairly cheap and it's a personal preference. Share this post Link to post Share on other sites
