Rhino37 0 Posted May 15, 2019 Recently had the idea to upgrade the TT-02 with Fastrax aluminium parts as a plastic hub carrier had broken in a crash. Went to Modelsport to buy some Fastrax aluminium upgrades but hit a stumbling block straight away. The rear of lower suspension arm is thicker at the hinge pin/pivot so it doesn’t fit into the rear suspension arm mounting plate. Has anyone used the same Fastrax aluminium suspension arms that can tell me what I need to do? Can’t find anything on YouTube/internet. The modelsport website says it’s compatible but it clearly isn’t a straight swap and offers no other parts to complete the process and neither does the fastrax website. Share this post Link to post Share on other sites
TurnipJF 9192 Posted May 15, 2019 Fastrax is not a manufacturer. It is a brand owned by CML Distribution, a UK-based importer of model products. They import their products from a variety of (typically Far Eastern) manufacturers and slap their own label on them. Unfortunately they don't seem to be too picky as to who they buy from, and quality is highly variable. Chances are the parts simply won't fit as they have been poorly manufactured. It might be a case of having to return or bin these parts and buy some from a reputable manufacturer with better production tolerances. 3Racing, Yeah Racing and GPM, while not perfect, are generally pretty good in this regard. And of course Tamiya items are pretty much guaranteed to fit without a problem. 2 Share this post Link to post Share on other sites
RCRod 4 Posted June 4, 2019 They are crap! I purchased the fastrax aluminium upgrades for my TT02B and found that they did fit but the mounting screws and spacers were useless and impossible to securely install dampers. I sent them back and asked for a refund from Modelsport 1 Share this post Link to post Share on other sites
DK308 219 Posted June 4, 2019 If you want alloy hub carriers, get the GPM units. They work great for me. 1 Share this post Link to post Share on other sites
nbTMM 433 Posted June 5, 2019 These ones? https://www.fastrax-rc.com/index.php?_route_=fastrax-tamiya-tt02-aluminium-rear-hub-carriers-2&search=tt02&page=2 Looks like they are just the Jazrider ones: https://www.jazrider.com/tamiya-tt02-aluminum-rear-hub-carrier-light-blue-p-90061693.html I actually have a set of those, and mine fit fine... until I stopped using them - get hubs with 2-3deg toe, much better than these which have no toe. If they are too tight, just gently hand file/sand the hub or arm until it fits. You actually want a tight fit on these because slop in the pivot will make the wheel flop around and lead to unstable handling. More often than not I find myself actually throwing 3mm shims in that joint to tighten it up, especially after parts have worn. Share this post Link to post Share on other sites
