hanzo
Brushed motors and 'sparks'
When I look in the motor on the bench I can see yellow sparks when its running (forward and backwards).
Some people mention that if there are sparks either:
  • motor has not been ‘run in’
  • brushes have worn out (replace brushes)
  • motor is dirty - run it in water to clean (?)
  • motor has debris inside - unassemble/clean/reassemble
What is the general consensus on sparks being emitted from a brushed motor while it’s running?
Personally, I don’t see any issue.  It’s only a backyard runner and motor has low runtime.
I guess as long as the sparks are not flying out of the motor or any smoke, it should be alright.
A degree of sparking is normal. If the sparks are small, there may not be any issue at all. Any chance of posting a video?
Yes, small sparks are fine.
You could put in in water and run it for a minute. (preferably between 4V - 6V)
Debris can get caught between commutator contacts.  If that's the case, cleaning can help.
This is good advice. A good cleaning in water is a great thing. There are several ways to do it. Personally, I have found that I get a better result by running it for a longer period in water slowly, than fast for a short time. I have made a "cleaning-pack" which is essentially a 3 cell nimh pack with 5000mah and motor leads soldered on rather than a battery connector.
Then I run it in demineralized.water for 20 minutes.
Then I run it dry, spray motor cleaner into the running motor. Then when that has "gone through" the motor, I wipe it clean and oil the bearings. The step of running the motor while spraying it with cleaner I find to be very good for getting the last gunk out that was loosened by the water.
Thank guys.  Great advise and something I can follow going forward.
13 hours ago, hanzo said:
I guess small sparks, maybe nothing to worry about?
Yep, that much is nothing to worry about.
