rjg1973
Toyota HJ40 Ute Custom Build
Hi TC folks.
I’ve been keen on a CR01 crawler build for some time and was planning to do a Toyota Land Cruiser 40. Inspired by my brother-in-law’s 1:1 truck I’ve decided to do a custom ute version instead. Here’s a pic of the real thing.
First step is to cut down the body from the 58405 Toyota Land Cruiser 40 CR01 kit to become the cab.
More to come!
After some online research and prototyping, the method I used to join the body was as follows:
On the inside, a layer of shoe-goo, drywall tape, and a strip of polycarbonate offcut as a sandwich. The offcut was from the unused middle section of the body so fitted well and was to stop excessive localised flexing of the join.
On the outside of the join a layer of JB-Weld epoxy.
A dusting of white paint to better see the surface as I plan to paint from the outside.
Eat, sleep, epoxy, sand, repeat.....
A little more progress.
I’ve opted for an SCX10 chassis - the builders kit. This gives three different wheelbases out of the box.
Based on various measurements of the cab, the scale is between 1:10 and 1:9. The longest wheelbase gives me 1:9.5, so that’s what I’m going with.
Proportions look pretty good, but unfortunately the rear suspension towers won’t work with the tray. Some thinking to do....
Finished painting the cab and the chassis now has axles. Still no solution for the suspension.
For the cab I used off the shelf vinyl cans. Pretty cheap and gives a good flexible finish.
45 minutes ago, rjg1973 said:
These do look good! Thinking I may be able to fabricate something similar.
There's a TRX4 / CMX version that looks similar too but if you can make the parts yourself, even better!
Thanks for that link too. I’m going to try and solve the suspension conundrum this weekend.
In the meantime, I’ve assembled and painted a killerbody tray. My original intent was to scratch build a tray, but this looks really nice and has working hinges and latches.
Cabin and tray resting on top of the chassis. Starting to take shape....
Hoping my integrated rear suspension and tray mount solution will work....
Sorted out the suspension and tray mounts.
Using CAD (cardboard aided design) cut and painted an angle section of aluminium for the suspension mounts.
These also have the magnets for the tray.
Suspension points are adjustable so I can fit smaller springs or adjust ride height.
Tray in position.
Suspension and magnetic mounts for the cab and tray all done.
Some front end detailing. Fly screen for the grills.
Styrene section for the front bumper.
Shaped, painted and fitted with winch opening.
A small flurry of activity over the weekend.
Jack with scratch fabricated mount, modified snorkel with fly-screen filter, wipers, wiper motor, shut lines.
Have begun fabricating rear mudguards.
youve done a really good job with the shutlines. Sometimes they can be a bit overdone but these look about right
