therealmonkeyracing 1 Posted June 9, 2019 Hi guys. Could anyone supply me with a few dimensions? I’m curious about the track width of a beam front axle, and the overall width to the outside of the wheels. I’m combating an SCX10 trail truck to 2wd and think this might be a good option, if the dimensions are right. Thank you for your help. Share this post Link to post Share on other sites
Stefan(2) 89 Posted June 11, 2019 My last one is boxed up , so no help from that atm.. YET.. think 2x .. the 1/14 axels ( front especially ) are a bit wobbly - at best There some options to make it more stable, but.. * mhe * and at first glance look at the scx10 ( google ) Wayyy to narrow for your use. Share this post Link to post Share on other sites
JennyMo 3526 Posted June 14, 2019 On 6/9/2019 at 1:37 PM, therealmonkeyracing said: Hi guys. Could anyone supply me with a few dimensions? I’m curious about the track width of a beam front axle, and the overall width to the outside of the wheels. I’m combating an SCX10 trail truck to 2wd and think this might be a good option, if the dimensions are right. Thank you for your help. Hi Monkey' - funny you should ask this (I think you mentioned it on another thread too recently?), as it's what I've done with my 2WD HiLux build here: I used an aftermarket 1:14 truck axle (from ebay), but they are basically the same - the overall width of the axle [ie. to the tip of the threads] is 181mm I'd say, while the distance between the two stub axle faces (where the inside bearings would sit - the front axle being the free-wheel type) is 145mm. This means you've got about 18mm of stub axle on each side. What I did was cut two tubular spacers (7mm long) which allowed me to space out the 1.7 truck wheels I used on the front so they fill the arches of my Trailfinder II cab - but I believe the SCX10 axles are about 15mm wider again than a Trailfinder/Gelande version? Hope that helps... Jenny x Share this post Link to post Share on other sites
