Sign in to follow this
vodka
DF02 damper
Hi, I need some help to solve a little issue. I have spent some money to pimp my levant (inspired by a revstorm picture) so when I put the df02 dampers the rear ones are too long... (and universal pops out from cups) How I can solve?
The length can be shortened using the little plastic spacers internally on the shock shaft (normally on the v parts tree) before you pop it through the shock body. Failing that a couple of o rings will work as well.
I have this spacer on the X parts... it's the right one?
in the front I have used a black oring (as manual), could I use 4 oring here or it's better the spacer ?
The o rings or that spacer will both do the same thing. Whichever is easiest for you.
I ask only to understand what is the most lasting solution
The plastic sleeve will last longest
