acprc
1/8 3097 Nitro Kyosho Turbo Burns restoration
Hi all,
My next documented restoration thread takes me away from Tamiya. As you all probably know I mainly collect Tamiya nitro however now and again I tend to drift towards other makes. In this instance Kyosho. The Turbo Burns came to me from Ebay UK. I paid £46 for it delivered in this condition:
Obviously missing a body, it has the wrong wing (its not an Inferno either) and covered in muck. First thing I have done with it is to jetwash the whole thing. Now that seems harsh but in actual fact it will be fully stripped, the RC gear will be scrapped anyway and the motor will be fully serviced. Other than that there is nothing that will get damaged. So jet wash done I am left with this to look over:
She is complete all bar the body, wing and air filter pretty much. Bodies are available as repro items along with the wing and decal set and the filter I think I already have. Wheels and tyres will be a challenge but we will see what happens.
The car is fitted with a nice period Mondial motor and I will try and restore that. It isn't seized so that's a good start. Some of the metal components are showing signs of rust and that awful jubilee clip exhaust tube will be going.
It has some nice aftermarket shocks fitted, hopefully these will clean up well. The rear arm threaded bars I already have new.
Chassis plate has a few marks but confident these should sand/polish out. I may replace it if I find a new one because I'm not a fan of extra drilled holes and this has a couple. All in all though a good starting basis.
More to follow soon when I strip her down.
@acprc i love your nitro builds m, subscribed.
perhaps when i rebuild my NDF01T you and @Tamiyabigstuff would be so kind as to answer approx 418 questions each :lol:
Yes I’ve done them all and have loads of parts so ask away
So, what are hot bank holidays for? Indeed, stripping a filthy nitro car. Finally managed to get the Turbo Burns stripped down.
Engine and chassis plate. A few bolts will need drilling out but should clean and sand up ok. Engine will be stripped and cleaned. @Disco the engine does have Pro on the mount etched on.
Lots of parts to replace that are damaged beyond restoration
Some sub assemblies to get apart and clean
Lots of hardware to be individually restored
Some parts to be salvaged for other builds
And as ever, bits for the bin!
So far so good, now to source a few parts. Stay tuned.
Had a bit of time on her today.
Managed to get the engine, engine mounts and part of the servo saver off the chassis. I had to drill the bolts out and then retap the holes. All the alloy parts are now ready to be cleaned and polished
With the engine off its ready to be stripped and cleaned. If you have seen my TGS Skyline build you will know the process it will go through. This Mondial 3.5 Pro engine will go back in the car.
Cross checked the new parts I had collected already against the bits from the kit. Mainly a few plastic parts, shafts and a new servo saver
and got the old bits in a box to sell on Ebay. These will still return a few pounds
Rest of the time was matching bolt and screw sizes from the manual to hardware on Ebay and ordering. The good thing about old cars is they use standard size screws so got most of the initial screws done.
The fuel tank is in the dishwasher ready for the next load. Once the outside is clean it will get a couple of denture cleaners inside with some hot water and a soak.
more to come.
Fuel tank came out the dishwasher and the inside had the denture cleaner treatment. Just needs the metal work sorting now but looking much better.
Washed and started to clean up the alloy parts. Lots more work needed but they are looking better already.
Took apart the front and rear hubs. Need to get some new pins to hold them on as the old ones are bent and the small rubber o-rings. The o-rings I should be able to match on Ebay. Blasted the hubs and axles ready for paint.
Matched the bearing to 8x16x5 668 size so ordered new as the old ones were in very poor condition.
Lots of new hardware arrived today.
As mentioned before no reason to pay Kyosho prices for cars this old as the hardware is easily matched.
The old girl is coming along. Front and rear gearbox assemblies are pretty much complete, cleaned up and new bearings and grease fitted. Purchased a hop-up rear shock mount for £9.50 on Ebay so awaiting that to arrive then I can mount the rear gearbox properly.
Also found a nice new brake disc on Ebay in France, just awaiting it and then I will strip the centre diff, replace the bearings and fit it.
Got the chassis plate as about as good as I am going to get it so started to mount parts as they get refurbished. So today she looks like this
Slow progress but starting to look like a car again. One of the front shock shafts is bent so just ordered another and then they will be refurbished and fitted. Then I guess its the radio plate and the engine. Need to find a front bumper, wheels and tyres. I can get a repro body and decals easily enough.
Got the engine stripped apart, was in very very good condition internally, no rust at all. Heatsink head will be blasted then polished, the rest will go through my normal process. All the screws and gaskets will be replaced as a matter of course.
Being Italian the Novarossi screws are the same. Needs a new clutch bell as the gear has separated from the bell. Should be easy enough to find.
Also got all 4 shocks dismantled and checked over. Apart from some rub marks on one of the rear cylinders all looks good. The new shock shaft is on its way. The springs have oxidised a bit so will decide what to do with them.
They will all be rebuilt with new seals, screws and rod ends. Plastic parts will be washed and reused and fitted with new screws.
More to come
Nice work!!! It's amazing how well Kyosho nailed the Turbo Burns. The basic layout is still used by all 1/8 buggies/truggies to this day.
I'm looking forward to seeing this one complete. Will you run it? Even just the back yard?
Yes, its surprising how similar it is to so many 1/8 buggies, even the new stuff.
The engine will get run on my test bench and then fitted into the car. I might run it, we shall see.
So spent some time on the centre diff this weekend. Stripped it down to have a look.
The inside was good with no broken teeth, cleaned and regreased the gears. Ordered a new spur gear as the old one was cracked, cleaned up the metal parts in the blast cabinet and fitted new bearings. Once the spur gear arrives I will build it up and fit it to the car.
Also, got the cylinder head blasted and then polished. Looks great.
Got some more parts done this week. New brake disc arrived so the centre diff was finished. Stripped and rebuilt with new bearings and retaining screws and then fitted back onto the chassis with the connecting driveshafts. Added the throttle servo.
Fitted the hop up rear damper support, looks nice and if I find a front one I will retro fit it
The Mondial 3.5 PRO engine was stripped, cleaned and rebuilt with new screws and gaskets. Came out really nicely.
Just needs a new clutch bell, the throttle connection and the mounts now. Heatsink head went back on the correct way round @Disco.
Started rebuilding the shocks now the shaft has arrived. Haven't decided on what to with the springs yet. Maybe just replace them.
More to come
Made a decision on the springs. Decided to blast them and try and repaint would be difficult due to paint falling off when they flex. Eventually found a new set in Italy for just £15 so purchased them. Another small item ticked off the list.
