Just collected a fantastic semi retro (it’s a post 2000 car I think) mad bull
Mint box, instructions, Tx, battery, charger etc
cant fault it bar a bit of a heavy paint job
im thinking I’ll strip the shell and paint it something different - I don’t have a pink car!!
not bad for £40
JJ
  • 4 weeks later...
  • 4 weeks later...
Just picked up these 2 off gumtree for £70
tamiya grasshopper (it’s not an original)
Reely Carbon Fighter 2 (just a rolling chassis)
plus all those wheels, plus 3 body shells
Subaru brat on average condition
Subaru Impreza in poor condition
monster beetle in..... erm......
well I guess it’s in 1 piece :)
some more pics of the Reely
metal chassis, 4WD, oil dampers, alu roll cage, rear drive with a little window in the top, split rear wing (maybe it’s got a DRS)
The chassis and the shell have just a carbon pattern printed
It’s a pretty nice looking car tbh
as for the beetle shell - it now has pride of place
an effigy to the Tamiya gods
JJ
thought I’d just list my collection
I made a list of all my cars ...
In cabinet....
-Monster beetle rerelease 2010
-Vanessas Lunchbox rerelease 2006
-Lunchbox in cannonball run guise 2019
On wall....
-Reely (not tamiya) carbon fighter 2 2015
-neo scorcher 2017
-terra scorcher 1988
-falcon 1986
-bear hawk 1991
-TT02b MS tamiya racing 2015
-grasshopper 2 2017
-baja king 2002
-koyosho nexxt 2015
-racing fighter black 2019
-tamiya wild one rerelease 2019
-tamiya mad bull 1995 - just off top right above light switch.
Desk...
-lunchbox mini 2019
-Grasshopper 1 rerelease 2005
-clodbuster 1987
For sale
-clodbuster 1987
On way
-manta ray rerelease 2018
-Durga 2007
happy to have dates etc amended
JJ
Been upgrading the neo scorcher
Suspension all round
slightly longer (supposedly 5mm front and back) but the white ones are already upgraded dampers (the base for my neo is a TT02b MS)
decided to for the yeah racing shock mount at the same time
The main issue is that the original tie rods are plastic
they secure with the stepped screw
the tie rod fixing hole is designed for that.
however the MS uses FRP tear shock mount with smaller holes to accommodate ball fixings for the tie rods.
these are too small for the holes in the yeah racing mount
some head scratching and I came up with heat shrink (2 layers of)
thoughts?
JJ
also fitted (a while back) DF02 metal diffs
thought I’d put the info here as I keep losing it all ;)
You need both these parts below
DF02 9400152 parts bag A (Gears) - normally £20 bag
https://www.modelsport.co.uk/index.php?product_id=26642
DF02 0555140 (2x cream 3 cog diff casing) - normally £7 pair
https://www.timetunnelmodels.com/live/catalog/tamiya-10555104-0555104-cream-colour-diff-gear-case-both-parts-special-order-p-61941.html
JJ
Today while hanging on the wall the neo scorcher started getting on my nerves
when I got it a few years ago id not built many before and this was my first poly shell so just followed the instructions, painted it all blue and applied the massive white decals over the cockpit
over time and crashes it looked awful
so thought I’d stay and remove the blue paint and the decals and try and do what I should have done which was mask and paint
so I masked off the inside and started using some paint remover applied with a paint brush and left till I could see it taking effect
was starting to peel nicely
as you can see I left the white decals on just in case the shell started to have issues
Once it was clear the shell would be ok I cut around the decals I wanted to remain and then started to peel the large white sections off to reveal the clear shell again
Fully stripped of paint and white decals
Few coats of PS-1 white
Et voila
soooooo much better And back where it belongs
along side it’s older brother
JJ
What paint stripper did you use? Looks to have been very effective. I’m imagining it’s the graffiti remover that we can’t get here in Australia?
i had to stop at 10 cars for now and still have two in box waiting .. my mancave is in my atic … away from the wifes eyes and moans ...
my list of wants is allways getting bigger , but end up paying out on all the mods for one car that I can buy another two with ….good work great thread ...
Q...them wheel hangers , will they hold the monster beetle or need larger ones ..?
They can be made bigger if you want
if you contact the seller he will make you up a bigger set too :)
https://www.ebay.co.uk/itm/184038479301
I have 4 builds going
grasshopper
subaru brat
manta ray
durga
pkus a Volvo 850 estate to paint up :)
JJ
grasshopper - complete
subaru brat hard shell - complete
subaru brat lexan - awaiting pink paint ;)
manta ray - still not started
durga - started (wow) but awaiting a brushless combo
TA-02SW - awaiting Vaillant kit from tamico
TT-02SR - en route from modelsport but alu shaft and cups not in stock (6R4 shell to fit)
volvo 850 wagon - awaiting paints
shame work gets in the way still
JJ
