got this delivered today
its my second QD and I got it because I like the shape
its in pretty good condition apart from some discolouration
Took the shell off and gave it all a clean
I’ll take the wheels off at some point and put them in the sonic cleaner
I’m liking it though 👍🏻
JJ
On 12/4/2020 at 8:58 AM, Problemchild said:
Picked up a few bits of tamiya from Japan recently also...
when I was v young, the lunchbox junior was all I could afford to own
JJ
I’ve just delved in to the world of mini 4wd too. Seems like a cheap way to get a fix when a full kit is not on the cards. I’m keen to start looking in to the mods. Also a good place to get the kids involved.
Managed to pick this up off eBay this weekend (I’ve been looking for a brushless 2WD basher and thought this was a bargain for £100)
not heard of the make before as I’m tamiya focussed but....
Team Durango DEX210 (2 being 2wd and 10 being 1/10)
in the deal it’s got
4000mah 2s + charger
brushless sensored motor
easyrun ESC
Tx and Rx
spare shells and chassis and parts
looking forward to giving it the once over. Anyone know much about this this make?
JJ
They were quite popular a few years ago, there were various configurations, the most popular for racing had the motor in the centre with a prop shaft to the rear diff.
Good info - thanks
hopefully I’ve not overpaid ;)
JJ
JJ
Not loads, but I think the quality is good. Looks like an ex club racer car. Will probably work well on astro or carpet with a mid engine layout.
Thanks - hopefully it’ll do well at the skate park - there are plenty of spares out there (which will be needed if the TT02b is to go by)
JJ
Well the DEX210  has not been as 100% awesome as I thought but still pretty impressed
Firstly the slipper was non existent and the slipper plate was glued to the spur gear which lasted about 30seconds of running on the desk
Secondly there were missing screws and a few missing parts and the rear wing was pretty destroyed
Finally because it was set up for racing, the ESC needs some work to get it running properly
But I’ve given it all a good strip down and clean and pretty impressed with the full FRP chassis
it’s also had a lot of extra parts to upgrade it to the V2 - metal chassis etc
it looks pretty sweet with the OEM shell
JJ
anyone know what part A2 are called and if you can buy them on their own?
The DEX210 is very similar to the Zahhak in how it’s assembled and those bits are missing from the build so the rear lower arms are a bit wobbly
JJ
JJ
Yep, they’re called Suspension Balls - 50994
Updated the neo scorcher with GPM tie rod and turnbuckle set (pics soon)
was also having servo jitter so tried a few servos and they were all the same but finally found one that had no issues (after swapping out the Rx as well)
also got some more updated parts for the DEX210 so it’s now almost ready to run
again, pics to follow
I need to clear/complete some of my projects
as an aside, me and my son built a small model greenhouse kit - some of the detail is bonkers but it came out really well
All items were built from base materials
(I.e. this cupboard was flat packed and the handles were cut from a gold Bit of wire and bent to shape)
we even went a bit further - note the tamiya masking tape cut into tiny little strips as tape for the painting
All so very fiddly
the stool has a material cover and the pencil on the easel is made of a blue cocktail stick, sharpened with a black tip added. We included an orange rubber for fun
To demonstrate scale...
anyway - final model...
includes working pendant light, handmade tools, cardboard black frame, tap with glue water drip and many many more bits (so many we just didn’t make)
was great fun though
JJ
The DEX 210 is finally back up and running
I thought I’d had some issues with the slipper / reverse
what was happening was the slipper was fouling in the motor plate and locking up
ordered a new layshaft spacer
The top shaft adaptor (shown below) was locking into the motor plate so this new spacer and 4 shims instead of 3 and it’s all running well now
the car was also short a few bits so got revolution design parts from RudDog in Germany (top deck bushings, battery plate and thumb screws)
it’s looking and driving so muncher better now
JJ
Thought I’d update my list of cars...
-Monster beetle rerelease 2010
-Vanessas Lunchbox rerelease 2006
-Lunchbox in cannonball run guise 2019
-Reely (not tamiya) carbon fighter 2 2015
-neo scorcher 2017
-terra scorcher 1988
-falcon 1986
-bear hawk 1991
-TT02b MS tamiya racing 2015
-grasshopper 2 2017
-baja king 2002
-koyosho nexxt 2015
-racing fighter black 2019
-tamiya wild one rerelease 2019
-tamiya mad bull 1995
-lunchbox mini 2019
-Grasshopper 1 rerelease 2005
-clodbuster 1987
-manta ray rerelease 2018
-Durga 2007
-TT02 SR with metro 6R4 shell 2019
-TA02SW (GT2 but with a 911 Vailant shell) 2016
-Subaru Brat 2007 (with hard and lexan shell)
-zahhak DN-01 2010
-hotshot 2007
-team Durango DEX210  v2 2015
-avante 2011
-clodbuster black edition 2019
-DT02 super fighter GR violet racer 2012
-MF01x Jimny 2015 (with TBG 959 shell)
JJ
Problem you are the man!  This is a great thread. I especially love your 540 coffee mug, Tamiya banner and of course all your cars. There are cars in this thread that I’ve never heard of so it seems like being gone from the hobby for 30 years, I’ve got some catching up to do.
I’d suggest subscribing to Tamiya legends and RC Kicks YouTube channels
loads of knowledge and great videos
JJ
Decided to upgrade my 11yr olds Kyosho NEXXT today
Because it’s part of the EZ build range, things like the gearbox, dampers, wheel etc are all pre assembled
it’s always been a great car to look at and to drive around (for a young-in)
I noted the damper units were hollow and were just like oil filled dampers but without the oil.
So I had a Google and there is a £7 kit
so I grabbed my child and a screw driver and off we went and disassembled the dampers
the kit contains lots of small spacers and washers
it’s easy enough to assemble
rubber washer / plastic spacer / rubber washer / plastic cap
x4
other end just a simple o-ring
unlike Tamiya you fill from the bottom and also unlike tamiya there is no rubber cap to create the air gap so it’s hard to know how this is gonna work
and as expected, initially they are totally incompressible.
What the instruction say is to keep the bottom seal loose and then move the piston so oil leaks out then wipe clean and tighten finally
anyway - fitted and they work ok
not bad for £7
Got my son to also fitted a 15T brushed thunderbolt motor just to give it a bit of extra speed ;)
JJ
