Oh no - just ordered a WLToys 144001 (yeah they don’t have names)
firstly and most obviously it’s not tamiya
secondly it’s RTR
and thirdly it’s 1:14 scale
but you know what - it was £90 with 3 x 2600 2s LiPo!!
so I chucked a full set of metal parts
2 Pieces Front Swing Arm
2 Pieces Rear Swing Arm
2 Pieces C-shaped Seat
2 Pieces Front Steering Cup
2 Pieces Rear Wheel Cup
2 Pieces Steering Component
1 Piece Big Gear
1 Piece Motor Gear
1 Piece Bottom Plate
1 Piece Drive Shaft
1 Piece Front Shock Mount
1 Piece Rear Shock Mount
8 Pieces Bearing
6 Pieces Pull Rod
£35
AND a phatbodies shell for £15
and all for under £150
(plus postage)
looking forward to getting my hand on it AND because I won’t have built it I WILL be running this one ;)
JJ
Decided to lower and widen the comical hornet
really easy to do.....
you need 3 things
1.  2x C parts tree for a WT01 (baja king) #0005688 (£8 each)
2. 2x mantaray drive shafts #9805551 (£8 pair)
3. 2x beetle threaded shafts #9805583 (£4 pair)
You need no additional screws or parts or suspension
the WT01 parts are a direct swap for the comical lower and upper arms - just longer
so - first remove the lower and upper arms front and rear
Then assemble the new lower arms with the screws from the original short ones and adding the ball connector for the suspension
the swap them over (including the one piece upper arms)
You then need to make the steering arms longer using the longer threaded bar (you may want to go for a slightly longer set Of bars - maybe 80mm)
and swap out the standard drive shafts with the longer ones and reassemble it all
Easy peasy
before and after pics
and
and these are all the parts you have left over
JJ
Side benefit of getting the C parts is you can also change the bumper
the 2 spring approach is ugly
So you can remove all these
Use the bumper and fixing from the C part
JJ
On 2/18/2021 at 10:30 PM, Problemchild said:
it’s defo quite square haha
I would call it "oversquare" :lol:
Wahoo - the wiltoys 144001 arrived - pretty nippy from China
it was £92 delivered (with 3 x 2600mah 2s LiPo)
have to say im impressed
looks and quality seem high.
Not gonna run it until I’ve added some grease to the diffs but here are the initial pics
Box is simple and packaged averagely
I went for the green one (I wanted the black spoiler)
Full metal chassis
lots of metal parts
JJ
Moved the battery clamps and added a longer battery strap
quick drive on the decking - seems pretty punchy
I’ll try it out a bit more tomorrow but I do want to put the extra grease in the diffs
JJ
Got my bling today for the 144001
Didn’t wanna go full bling and my main reason for buying was for spares
tries the steering system but the tolerances are too tight
went for the main chassis brace /top deck (used a hair dryer to warm the adhesive and peel the ESC/receiver combo)
also installed rear wing support
looks nice now
i also disassembled the diffs for greasing
took off the tops of the doff covers, removed the diffs, unscrewed and packed with some Tamiya grease.
Inside the diffs themselves there was some grease. On the outside ther was some grease but on the diff housing and not on the outer gearing.
on the pinion and spur gear there was nothing.
I was going to replace the plastic spur gear with the metal one in the set but I was unable to remove it from the prop shaft.
JJ
How do they perform? I'm looking for something 2WD for running in my backyard and I would like to have a Buggy with a good performance. Something that will take corners without too much understeer. Will be driven mainly on grass.
Excellently - I’ve only ever driven Tamiya but wanted a 2wd bashed and saw the white one and bought it but it needed a lot of work and spent a few months restoring it - even needed a new esc last week :(
it really surprised me how good it was
im selling them both and tbh just advertised them on Tamiya legends.
selling them together as a pair for £140 plus a bit of postage
or
£80 for the yellow one or £60 for the orange one
ive also got a whole heap of wheels
PM me
some pics
JJ
Just read that Team Durango didn't exist anymore! That make the availability of spare parts at least difficult. Here in Germany are the rest of the parts on clearance sale. I think I will have a look for other makes first. But thank you for the offer.
Yeah no probs - they are v tough being FRP though but I share your concerns
I have lots of spares
JJ
On 2/19/2021 at 5:17 PM, Problemchild said:
Finished the Avante
a lovely build
very heavy though
PS16 backed with silver backed with black
technigold motor
JJ
That’s hot!!
JJ
This looks like a fun modification. Any idea how similar that chassis is to say something like my Honda city Turbo?  I’d like to do something like this.
Looking at Tamiya base it’s exactly the same chassis so looks like no reason why you couldn’t just buy the 2 parts trees and drive shafts and steering arms to lower and widen the  car
assuming you have the rere city turbo
JJ
JJ
Yes and I’d like to put larger tires in it and this seems like a way that it can be done.
Yeah - you can get 2 sets of front or backs as even thought it’s 2wd both wheels are hex
JJ
