Sign in to follow this
dave.723
Monster Racer: Universal replacement
Hey,
I managed to strip the universals, seems the wheel got a bit loose and so the wheelhub. :( . Are there any modern direct fit replacements out there ? will a CVD from a DT02 fit ? (Manta Ray, TopForce, ...)
Many thanks
Has it stripped the splines on the drive shaft or just the ones in the hex?
Not sure on the drive shaft but hexes should be available.
The splines on the shaft have stripped.
If astute uses the same lengths (bones and wheel axles) than this article lists options. Which would be great.
2 hours ago, MICHAELs TopForce17 said:
great! thanks! here you go with some measurements. I would like to use modern universals with pin mount for the wheel hub ...
I think what you need are Blitzer Beetle/Stadium Blitzer uprights which are the same as the astute series but the inner bearing inserts further into the upright. Then you can use modern thundershot/top force axles and shafts. Get one of the monster racer officionados to confirm though.
Many thanks ! I will try that with my next order and resurrect the thread then.
  • Recently Browsing   0 members
  • Who's Online   1 Member, 0 Anonymous, 21 Guests (See full list)
  • Today's Birthdays
    1. andriesb (43 years old),
    2. mikef350 (38 years old)
  • Member Statistics
    49187
    Total Members
    972
    Most Online
    Kiwicath
    Newest Member
    Kiwicath
