Carts 102 Posted July 23, 2019 Need help. What spray or paint do I need to use on the f350 mirrors Share this post Link to post Share on other sites
Juggular 4964 Posted July 23, 2019 I have a Hummer and it has unbreakable flexible rubber mirrors. Anything I paint will come off. So I put pieces of aluminum tape. They have not come off since 1995. This it not real shiny, most of the times they just look white. But they are passable. It's useful in the light buckets too. They reflect light well enough. I drilled out and glued clear plastic and scored the lines with a knife, so they look kinda butchered, but again, passable enough from afar. If you want something shinier, you can use shiny silver sticker like AAA sticker they used to mail you every month (that was a long time ago). The the AAA sticker itself isn't mirror-like. It's got perforations so it won't reflect sun in the eyes of the driver behind. But outside the sticker, the unused part is mirror like. Maybe you can find foil tapes in arts and craft store? There must be plain mirror-like stickers (not the twinkly or narrow ones like below). Share this post Link to post Share on other sites
topforcein 1764 Posted July 23, 2019 i dont know but when i painted the fender flairs for my bruiser which are rubber i used tamiya fine surface primer and tamiya ts paint followed by clear coat and for some reason they feel sticky know. perhaps i did something wrong Share this post Link to post Share on other sites
Juggernut 120 Posted July 24, 2019 I haven't tried it, but maybe Flex Seal Spray? www.flexsealproducts.com Share this post Link to post Share on other sites
Busdriver 6209 Posted July 24, 2019 Are you trying to replicate the glass part of the mirror or paint the frame itself. If it's glass then some form of sticky backed foil would be best if its the frames Im not sure what you could use? Rubber is notoriously difficult to paint. Even more so than loveable lexan!!!!!! Share this post Link to post Share on other sites
SuperChamp82 743 Posted July 24, 2019 Self adhesive chrome foil is the nearest I’ve found for rubber mirror inserts. And commercial marine paint (used on boat hulls) is expensive but holds longest before cracking on the mirror body - noting anything will suffer eventually on bendy items like these. Share this post Link to post Share on other sites
