Honza 913 Posted September 1, 2019 22 hours ago, Juggular said: Differentials in the central tube would be nearly impossible with an RC version. It is possible, there are homemade 1:14 scale replicas of chassis with functional diffs. But I'm not sure what's their lifespan, it'd definitely need hardened steel gears, which wouldn't be cheap (those replicas I'm talking about cost several times as much as Tamiya RC trucks) But there's another solution - Pinzgauer is based of same idea, but it has bevel differential between axle bevels, which might by usable in RC. I think that Tatra concept would be great for Tamiya, since it uses lot of duplicate parts, which is ideal for plastic model. But since it's used by single truck manufacturer, it doesn't make much sense to produce it.. 1 Share this post Link to post Share on other sites
dc-arena 81 Posted September 2, 2019 More details on this model: https://tamiyablog.com/2019/09/tamiya-58675-mercedes-benz-g-500-cc-02-chassis-cross-country-2-official-details-and-description/ Share this post Link to post Share on other sites
TurnipJF 9111 Posted September 2, 2019 This looks interesting: • Includes: Tamiya TBLE-02S ESC (electronic speed control) Capable of running sensor brushless motors and brushed motors alike. (21.5 Turn BL motor limit) (23 Turn brushed motor limit. Note the motor limit. Do we think this is because the chassis has more drivetrain drag or weight than usual so stresses the ESC? Have Tamiya reconsidered the spec of the TBLE-02 for all models? Or is it simply a typo? Share this post Link to post Share on other sites
Juls1 1653 Posted September 2, 2019 It’s a typo, myn will be getting a hobbywing WP-Crawler esc. I suggest everyone else does the same. With that 29:1 ratio a stock 540 should be slow enough! But I’ll prob change it to something that’s slower and can handle 3s. Share this post Link to post Share on other sites
nowinaminute 2813 Posted September 2, 2019 I think it looks pretty good. I know it could be considered to be more conventional and less interesting but we all know this basic layout gives a good compromise between ability and scale looks and I'm not going to complain about tamiya making stuff that's more competitive dynamically. One thing that pleases me is that there is a lot of new plastic being used here. Does this mean we might begin to see more new designs with less parts bin recycling soon? A new MT type platform maybe? Maybe a new Wild Dagger type platform but with decent front kickup etc...no, don't do it. Don't get your hopes up. Share this post Link to post Share on other sites
taffer 946 Posted September 2, 2019 Weird but suddenly I'm feeling nostalgic for the cc-01! I've been looking at the hilux extra cab because it's the latest release thinking if this is the last ever release, should I get it???? seems crazy? Share this post Link to post Share on other sites
makya 13 Posted September 4, 2019 I've only read the last few pages, but I wonder if this isn't tamiya "dipping their toe in the water", so to speak. it looks like the chassis is a little nondescript, which would make changes to suspension, drivetrain and body adaptability easier. i do wonder why the axle truss is on the bottom though. Share this post Link to post Share on other sites
taffer 946 Posted September 4, 2019 (edited) Nice to see already model number 47441 cc-02 with pre-painted g500 body its coming up to winter when released, so a nice option to get up and running without waiting for good paint spraying conditions plus tamiya do a great job of painting! thanks to @Mokei Kagaku for this info Edited September 4, 2019 by taffer giving credit where due 2 Share this post Link to post Share on other sites
taffer 946 Posted September 4, 2019 6 hours ago, makya said: I've only read the last few pages, but I wonder if this isn't tamiya "dipping their toe in the water", so to speak. it looks like the chassis is a little nondescript, which would make changes to suspension, drivetrain and body adaptability easier. i do wonder why the axle truss is on the bottom though. Isn't the idea for that it is stronger that way? (tougher over obstacles) how tamiya seemingly have done it means it doesn't look like it will impact on performance? Share this post Link to post Share on other sites
makya 13 Posted September 4, 2019 6 hours ago, taffer said: Isn't the idea for that it is stronger that way? (tougher over obstacles) how tamiya seemingly have done it means it doesn't look like it will impact on performance? Not necessarily. The way that we add trusses to full size rockcrawlers, is on the top, and across the front or back if the axle has a pull out 3rd member like the Ford 9 inch. Some still put small braces across the bottom, but not big, just enough to fight separation at the connection of the axle tubes to the center section be cause they are separate pieces. With r/c cars, the housing are molded with the center section and tubes together, so that adds some strength already. As for the truss; think of the axle like a door. You, as the force working against it, want to push the door open. Will you find more resistance with the door boarded up on the opposite side of your force, or boarded up on the same side? 1 Share this post Link to post Share on other sites
taffer 946 Posted September 4, 2019 Well you know Tamiya! They always like to buck trends and go their own way!? 😁 Share this post Link to post Share on other sites
geniusanthony 361 Posted September 4, 2019 39 minutes ago, makya said: Not necessarily. The way that we add trusses to full size rockcrawlers, is on the top, and across the front or back if the axle has a pull out 3rd member like the Ford 9 inch. Some still put small braces across the bottom, but not big, just enough to fight separation at the connection of the axle tubes to the center section be cause they are separate pieces. With r/c cars, the housing are molded with the center section and tubes together, so that adds some strength already. As for the truss; think of the axle like a door. You, as the force working against it, want to push the door open. Will you find more resistance with the door boarded up on the opposite side of your force, or boarded up on the same side? Nice analogy 1 Share this post Link to post Share on other sites
makya 13 Posted September 4, 2019 19 minutes ago, taffer said: Well you know Tamiya! They always like to buck trends and go their own way!? 😁 How true! My first r/c was the original Pajero on 1985, which was odd compared to the buggies and trucks of the day. I would be really happy though, if they found enough interest to build a TRF-level scale crawler. Share this post Link to post Share on other sites
taffer 946 Posted September 4, 2019 Maybe if this proves popular, who knows they may quickly expand the range!? 😁 1 Share this post Link to post Share on other sites
khyzersoze 268 Posted September 4, 2019 The axles look like they're upside down with the trusses at the bottom. I wonder if it's an assembly error. It looks like you might be able to flip the axle and relocate the link mounts to the other side too. Share this post Link to post Share on other sites
Bromley 681 Posted September 4, 2019 4 minutes ago, khyzersoze said: The axles look like they're upside down with the trusses at the bottom. I wonder if it's an assembly error. It looks like you might be able to flip the axle and relocate the link mounts to the other side too. I agree...I was just about to post the same. Share this post Link to post Share on other sites
KING_TUBBY 10 Posted September 5, 2019 12 hours ago, taffer said: Maybe if this proves popular, who knows they may quickly expand the range!? 😁 Yes, I would personally love a 6x6 Dakar racing truck based off this platform! 2 Share this post Link to post Share on other sites
Mokei Kagaku 2706 Posted September 13, 2019 Confirmed content of 54910 CC-02 Full Ball Bearing Set: 16 pcs. 1150 2 pcs. 850 2 pcs. 1260 2 pcs. 1510 My guess how they are used: Rear axle: 6 pcs. 1150 Front axle: 6 pcs. 1150 Uprights: 1 pc. 1260 and 1 pc. 1510 each (like CC-01) Gearbox: 4 pcs. 1150 and 2 pcs. 850 (judging by the available "x-ray" view of the gearbox, it uses 6 bearings of partially different sizes) In other words: no ball bearings included in the car kit. 1 1 Share this post Link to post Share on other sites
tpliquid1 2 Posted September 17, 2019 tamiya usa fb post : 2 Share this post Link to post Share on other sites
lsear2905 1279 Posted September 17, 2019 17 minutes ago, tpliquid1 said: tamiya usa fb post : Yay. Phillips' head screws. C'mon Tamiya. 1 Share this post Link to post Share on other sites
Nicadraus 6130 Posted September 18, 2019 2 hours ago, tpliquid1 said: tamiya usa fb post : Looks rigid. Are the side frames made of metal/steel? Share this post Link to post Share on other sites
shenlonco 1156 Posted September 18, 2019 1 hour ago, Nicadraus said: Looks rigid. Are the side frames made of metal/steel? Nope looks like plastic as you can see the white colored marks from the spot they trimmed them off a parts tree. Share this post Link to post Share on other sites
tpliquid1 2 Posted September 18, 2019 hopefully someone will make some metal rails for it. more from their instagram https://www.instagram.com/p/B2iEvOgFSbM/?utm_source=ig_web_copy_link Share this post Link to post Share on other sites
tamiya3speed 461 Posted September 18, 2019 Was not expecting plastic frame rails. Interesting selection for sure. Share this post Link to post Share on other sites
Blista 1517 Posted September 18, 2019 Tamiya will release blue, white and red plastic rails. And later some blue aluminium ones. And then silver aluminium ones. And then some "special edition" black aluminium ones. And you'll all buy them. Edit: here's the latest instagram photos 4 Share this post Link to post Share on other sites
