Hi all,
I'm in the progress of building a custom 3d printed pan car chassis. Printing a body would take a lot of time and would not be a strong as a lexan of ABS shell.
I was thinking of using a Kamtec Mini body in combination with Tamiya 60D tires (m-chassis). I know they use smaller tires normally for these bodies.
Can anyone confirm or deny that these tires would fit ? I can't find any reference online.
The Kamtec bodies are generally 1/12th scale with wheels to suit the bodies . The Tamiya '60D' are for 1/10th scale M chassis , so might be slightly too big  . The Kamtec site has various dimensions available for shells and wheels and can then be compared to the Tamiya wheels .
hello
        just looked tamiya mini are 57mm height and 25mm wide,hex fit with rubber tyres,kamtec are 50mm height and 25mm wide,with foam tyres.normal to run with out bearings but you can get bearing ones now f2,stockcar.
