Rcbasher 1 Posted September 6, 2019 Morning everyone, ive been painting a D90 hard body and the paint has reacted. I used Tamiya's fine surface primer then degreased with IPA and finally passed over with a low tack rag. Then I done a couple of coats with a Tamiya Ts gloss white. Then this happened :( Any help would be appreciated. Share this post Link to post Share on other sites
topforcein 1764 Posted September 6, 2019 where did you paint it cause it looks like where ever you have painted it their is either silicone of polish been used in the area you have to strip it of as it looks like it gone down to the surface that is what i call "fish eyes" reaction 1 Share this post Link to post Share on other sites
nbTMM 433 Posted September 7, 2019 Yeah those are fish eyes, which are caused by surface contamination that the paint won't adhere to. Maybe the IPA or tack cloth cleaning steps left some residue that the TS paint doesn't like, or it got contaminated with some other type of overspray. Building up a series of very light mist coats before spraying a heavier coat can also help. Share this post Link to post Share on other sites
Rcbasher 1 Posted September 7, 2019 I see what a pain, what paint pre cleaners do you guys use? Especially with acrylic paints? Share this post Link to post Share on other sites
Fuijo 880 Posted September 7, 2019 After priming with T's fine surface primer, I just wash it in lukewarm water with a bit of dishwashing liquid, and leave it to dry thoroughly underneath an upturned plastic crate to protect it from dust. Using tack cloths is risky because they can leave a stickyness on the surface that contaminants can stick to. The problem your pics show can also be caused by paint that isn't mixed very well. I always shake the cans for several minutes, up to 5 or so, particularly in less than searingly hot weather, and stand the can in the sink with bath-temperature water about half way up the can for another 5 minutes. Share this post Link to post Share on other sites
topforcein 1764 Posted September 7, 2019 where about did you paint the shell. all the hard body shells ive painted i have only washed with the washing up liquid and a sponge and only at the start before painting 1 Share this post Link to post Share on other sites
Apexape 13 Posted September 8, 2019 Dumb question but did you completely open up the tack rag and then scrounge it back? Also was the surface completely dry before you tack ragged it. When i used to paint 1:1 that could sometimes cause fish eyes from the tack material. But other than silicone contamination it looks like you probably went pretty heavy on the paint with the solvents releasing mold release agent through the primer. Share this post Link to post Share on other sites
Rcbasher 1 Posted September 9, 2019 I fully opened the rag but went over lightly as to not to transfer contaminates. It was dry before that process. I went over with 2 light coats and it started to react then I thought F#*k it and carried on. Hanging my head in shame now, as its more work for me to rub it back. 🙄 Share this post Link to post Share on other sites
Apexape 13 Posted September 10, 2019 Only thing i can really think of is silicone contamination. Like someone mentioned above, where did you spray? Share this post Link to post Share on other sites
87lc2 2666 Posted September 15, 2019 That's a bummer, hate it when that happens. As others have said, definitely caused by contamination. I always wipe doen my surface with isopropyl alcohol a few minutes before spraying and never have an issue. Alcohol is great at getting rid of contaminants and gives a great surface to start with. Just painted a Bruiser body today that I sanded a while back, just wiped it down with some alcohol, shot base then clear and it came out nice. Share this post Link to post Share on other sites
max69vk 708 Posted September 16, 2019 as Mentioned 100% that is Silicone contamination, the thing to remember is that no matter how much you clean the body before you spray if the silcone is in the air/environment you're spraying in it will be attracted to the plastic body due to static charges. Share this post Link to post Share on other sites
Rcbasher 1 Posted September 23, 2019 Happy Monday, Thanks guys fir your input 🙂 what grade paper should I use to flat this mess of paint back? Please 😚 Share this post Link to post Share on other sites
Apexape 13 Posted September 27, 2019 In order not to destroy the plastic or put really deep scratches in it i would wet sand with 400 grit. It is going to take a while. You can sand it dry too. Itll be a little faster but scratches will be a little deeper. Then prime really good after a really good cleaning. If you are feeling froggy you can start with 180 and work your way up. The trick is to let the sandpaper do its job and not dig or push into the surface. It will get the paint off exponentially faster but i do not recommend if you are not experienced in auto body repair. The scratches will be very noticable and will take some time and work to get out Share this post Link to post Share on other sites
Rcbasher 1 Posted September 28, 2019 Ah thank you, maybe it's a little job for this weekend, it's very wet and windy here. Thank you again Share this post Link to post Share on other sites
WillyChang 1814 Posted September 28, 2019 Sand big flat areas like that supported with a block, not raw paper in your fingers. Big pencil eraser or a cut down cork block is good. Those big nail buffer files that look like tongue depressors are good too to wrap your sandpaper around. Share this post Link to post Share on other sites
