Blissard 359 Posted September 22, 2019 I'm thinking of reducing the diameter of my Hilux tires to fit 1.55 wheels and I have some questions; How do you cut rubber smoothly? What type of glue is the best ? Can I weld by melting instead of glue ? How do you make it look like no work has been done on the tires ? ... This it the look I want for my FJ40: Thanks in advance : ) Share this post Link to post Share on other sites
WillyChang 1814 Posted September 22, 2019 Superglue cyanoacrylate works well enough joining cut tyres together. you could reinforce it inside with an extra patch glued with contact rubber cement, or maybe a vulcanising rubber patch like on bicycle inner tube puncture repair... but I doubt most don't bother. Sharp scissors or scalpel cuts rubber well enough. Lubricate with water if you have to. Plan your cuts to maximise butt-joint contact area & preserve the tyre thread continuity if only for looks. 1 Share this post Link to post Share on other sites
Blissard 359 Posted September 22, 2019 Thank you! Tire thread continuity is definitely very important. I'm mostly worried about a line on the side walls. Share this post Link to post Share on other sites
Apexape 13 Posted September 27, 2019 Looks like it would take alot more work than finding suitable tires for the wheels you want to use. Do you plan on running these wheels and tires or using them on a shelfer? Share this post Link to post Share on other sites
nbTMM 433 Posted September 28, 2019 I think even if you cut it and glued it back together perfectly, it would still be out of round because the tyre is going to want to maintain the radius that is was molded as. It will probably assume an egg shape not unlike your last picture. Share this post Link to post Share on other sites
Butler 338 Posted September 28, 2019 http://www.tam.ne.jp/nic/tires/tires_01e.html might help. 1 Share this post Link to post Share on other sites
Blissard 359 Posted September 29, 2019 Thanks for the replies guys. I've decided to keep them original and use 1.9 wheels instead. If I reduce them they will also look too short and wide. And I am planning to run them. My observation; Hilux tires are close to 1.8 size and they fit Tamiya 1.9 plastic wheels nicely, they don't work with rc4wd 1.9 wheels. Share this post Link to post Share on other sites
WillyChang 1814 Posted September 30, 2019 are those repop hilux tyres? Was just thinking the originals on the steel wheels have that plastic ribcage holding them round... that wouldn't be too easy to cut-n-shut Share this post Link to post Share on other sites
Blissard 359 Posted October 2, 2019 On 9/30/2019 at 8:36 AM, WillyChang said: are those repop hilux tyres? Was just thinking the originals on the steel wheels have that plastic ribcage holding them round... that wouldn't be too easy to cut-n-shut Yes. I bought them on ebay while they were available, should have bought Blazer tires as well. I would rather make new ones than cutting the original ribcage. It's even very difficult to hold them or place in tires. Share this post Link to post Share on other sites
WillyChang 1814 Posted October 3, 2019 Darned, have the repops dried up? Was thinking of getting some, then got distracted by Life. Ah well... Yeah was thinking of drawing up the ribcage and squirting something out on 3D printer. One day! Share this post Link to post Share on other sites
Blissard 359 Posted October 3, 2019 Yeah, haven't seen them for years. I hope they will be available again one day, the quality was amazing. I just remembered that I also bought their soft Bruiser tires. Share this post Link to post Share on other sites
WillyChang 1814 Posted October 3, 2019 Hilux is an odd size, the repops would've been handy. Blazer rubber would be godsent for M38 Willy owners. Bruiser otoh is 2" and over the years there's been various alternatives. I think the Monster Beetle tyres are softer? There's also some 3rd party lookalikes... I've had some going back to the 90s, with yellow bag tag... branded CRC or something like that. They're pretty soft, have doubts they'd even support a Bruiser they're probably more for Blackfoot maybe. Share this post Link to post Share on other sites
Blissard 359 Posted October 3, 2019 Yeah, I always thought Hilux tires are 1.9 but they are little bit smaller, still bigger than 1.7 though. Repops are also same size as originals, the maker of those should have offered them in 1.9 also. I agree with soft tires on Bruiser. Aftermarket soft Bruiser tires can't even carry an iphone so they're also too soft for a Blackfoot. Share this post Link to post Share on other sites
mongoose1983 3335 Posted October 20, 2019 Why don't you glue some ring rubber pieces taken from old tires correct size to mount your Hilux tires on those wheels instead of cutting 'em out? Share this post Link to post Share on other sites
Blissard 359 Posted October 21, 2019 Do you mean replacing tires side wall ? I think it would look more messy with a cut line all around the tires. Share this post Link to post Share on other sites
mongoose1983 3335 Posted October 21, 2019 No, actually to use extra rubber to "reduce" or "fill" the gap between the Hilux tire and the wheel you want to use. Share this post Link to post Share on other sites
Blissard 359 Posted October 21, 2019 I understand now. That's great idea! I will make a small test see how it looks. Share this post Link to post Share on other sites
njmlondon 570 Posted November 27, 2019 Are you replacing the wheels on a vintage Hilux 3-speed? If so I am interested to know whether you have swapped out the axles or modified the originals? On another note, if you want genuine Goodyear tires for RC4WD rims, they do a large range... https://store.rc4wd.com/Goodyear_c_772.html 1 Share this post Link to post Share on other sites
Blissard 359 Posted December 24, 2019 On 11/27/2019 at 3:14 PM, njmlondon said: Are you replacing the wheels on a vintage Hilux 3-speed? If so I am interested to know whether you have swapped out the axles or modified the originals? On another note, if you want genuine Goodyear tires for RC4WD rims, they do a large range... https://store.rc4wd.com/Goodyear_c_772.html Sorry for late reply. I was planning to use those tires for another truck but decided to postpone that build. But I did modify Bruiser axles to accept pins in order to use standard wheels. 1 Share this post Link to post Share on other sites
