Frh076 2 Posted October 6, 2019 Can i bond two pieces of dry carbon fiber together by adding epoxy resin and a piece of carbon fiber cloth? Do i have to heat the dry epoxy, before i do it? Or will this not work? Any other ideas anyone? Share this post Link to post Share on other sites
Collin 1956 Posted October 6, 2019 Sandpaper the surface a bit and glue it together with 2k epoxy glue. It will last forever. I made 3mm brakediscs out of 1,5mm fiber sheets. Works like a charme. 1 Share this post Link to post Share on other sites
ThunderDragonCy 7878 Posted October 7, 2019 8 hours ago, Frh076 said: Can i bond two pieces of dry carbon fiber together by adding epoxy resin and a piece of carbon fiber cloth? Do i have to heat the dry epoxy, before i do it? Or will this not work? Any other ideas anyone? If you are looking to do that (which is effectively wet laying) it will need some compression to wet out all the fibres and a hardener to get the epoxy to go off. If there is space it's easier to make a lap joint by bonding another carbon plate over the split usibg the technique mentioned by @Collin Share this post Link to post Share on other sites
Frh076 2 Posted October 7, 2019 15 hours ago, Collin said: Sandpaper the surface a bit and glue it together with 2k epoxy glue. It will last forever. I made 3mm brakediscs out of 1,5mm fiber sheets. Works like a charme. Can you please link an example of this glue? Is it the power epoxy glue from loctite? Share this post Link to post Share on other sites
Collin 1956 Posted October 8, 2019 https://www.amazon.de/Plus-Endfest-2-K-Epoxidharzkleber-Binder-Härter/dp/B000KJP0QK/ref=asc_df_B000KJP0QK/?tag=googshopde-21&linkCode=df0&hvadid=309874708970&hvpos=1o3&hvnetw=g&hvrand=7568192089607234502&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=1000701&hvtargid=pla-724108201327&psc=1&th=1&psc=1&tag=&ref=&adgrpid=67375073971&hvpone=&hvptwo=&hvadid=309874708970&hvpos=1o3&hvnetw=g&hvrand=7568192089607234502&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=1000701&hvtargid=pla-724108201327 I dont know if you can get this brand, but there is also one by loctite. Its simply 2x-epoxy glue. Share this post Link to post Share on other sites
Collin 1956 Posted October 8, 2019 https://www.amazon.de/UHU-Endfest-Plus-Zwei-Komponenten-Kleber-lösungsmittelfrei/dp/B0774J8L9J/ref=pd_sbs_229_2/258-6756080-0029622?_encoding=UTF8&pd_rd_i=B0774J8L9J&pd_rd_r=23fe9c64-db54-42c5-8dfc-73b82296b485&pd_rd_w=6hVWM&pd_rd_wg=kxiZh&pf_rd_p=74d946ea-18de-4443-bed6-d8837f922070&pf_rd_r=R6T1DNQ18DN5PDSQ6GAY&psc=1&refRID=R6T1DNQ18DN5PDSQ6GAY Share this post Link to post Share on other sites
