I'm running a 7700kv /3s in my Dark Impact.
If it's for just one run, my money would be that it would be fine as is,(presuming the balls diffs are setup right, and it's ballraced?)
If it's going to be sitting in there full time, I'd recommend a slipper (if you're upto it, the hardened main shaft gear mod too), and swapping out the rear outdrives for the single piece front ones. Ive replaced driveshafts, but only because I lot mine when the turnbuckles popped off in a crash.
