KEV THE REV 2319 Posted October 26, 2019 I've got some steel pinions here and I can see how many teeth , but don't know the pitch , how can I work that out ? , thanks . Share this post Link to post Share on other sites
WillyChang 1814 Posted October 26, 2019 I go grab a spur of known pitch to compare... 1 Share this post Link to post Share on other sites
Wooders28 4723 Posted October 26, 2019 6 hours ago, WillyChang said: I go grab a spur of known pitch to compare... Try comparing an 05mod and a 48dp, 0.02mm of a difference 🧐😬 Share this post Link to post Share on other sites
WillyChang 1814 Posted October 27, 2019 4 hours ago, Wooders28 said: Try comparing an 05mod and a 48dp, 0.02mm of a difference 🧐😬 Ah... I keep my DF03 spares quarantined far away in solitary confinement in Dark Impact's kit box whereas 48dp run free range everywhere else... I usually texta on the teeth count & type on Spurs anyway I write on pinions too but often the ink gets washed off with motor spray. Too tired to break out the engraver to do every pinion. 04m & 64dp are the biggest mixup risk got near equal population of each size. Easiest way to tell is nearly all my 04m are Tamiya & they're not steel. For or multiples of same pinion, I slip them onto a piece of aerial tube. Holds them all together, handy to grab when packing for track. (Yeah there's 'overflow' as expected, I don't need to pack more than 2-3 each size. Extras live in usual tackle box. Tackle box has habit of spilling its lid, got tired of resorting contents every spill.) 1 1 Share this post Link to post Share on other sites
nbTMM 433 Posted October 27, 2019 15 minutes ago, WillyChang said: 04m & 64dp are the biggest mixup risk got near equal population of each size. Easiest way to tell is nearly all my 04m are Tamiya & they're not steel. They are so close (<1%) that they are effectively the same thing though. The teeth on small gears are not usually 100% accurate, they just have to be good enough. The cutting tools that create the teeth have a tooth range, so that one cutter may create the teeth on gears anywhere from 50teeth to 100t. It'll be perfect making teeth on a 50t gear but by 100t is considered just barely close enough - if you want to make a 101t gear you should get a different cutter. For that reason, the inaccuracy between two 64dp or 0.4M gears may be greater than between a 64dp and 0.4M. I wouldn't be surprised if in the industry people use the metric and imperial cutters interchangeably between similar pitches 1 Share this post Link to post Share on other sites
speedy_w_beans 4272 Posted October 27, 2019 If you have digital calipers to measure gear diameter and know the number of teeth, this page of gear calculations should give you pinion pitch: Here Count the number of teeth, N. Measure the outside diameter, DO, with the calipers. Calculate diametral pitch using P=(N+2)/DO or P=(N+1.6)/D0 depending on the style of gear tooth. Calculate circular pitch, p, which is the pitch you're interested in, using p=3.1415926/P. Done. 2 Share this post Link to post Share on other sites
