Hey Guys!
I was about to install my Servo, ESC and Receiver in the Avante, when I did a function check first. Everything is new, so I thought it should work. But it doesn't.
The receiver light is on permanently, meaning it has connection to the transmitter, but the servo does not turn and the tamiya ESC is blinking, meaning no transmitter detected.
How can that be? The transmitter is a Carson Reflex wheel.
Thanks in advance!
Always the first suspect is not bound properly (but you said that there is a connection with the transmitter).
Next would be the battery.  I assume the transmitter has good batteries and the car battery is also charged up?
Have you tried to do the binding process again?  It should reset everything.
