blofeld
Mad bison resurrection
Apologies if wrong forum- not strictly in the first 150 I don’t think.
Found my old Mad Bison in the garage and thought I’d pimp it a bit.
Tgm-01 chassis. Basically a TG10 with wild dagger suspension. As a result hop ups are pretty hard to come by nowadays.
first problem- ride height shocking. Lots of slop in the shocks and travel poor as they are basically touring car. I extended them to 80 and fitted stiffer springs which has helped. Ideally I’d like a alloy shock tower to enable 100mm shocks like wild dagger/twin detonator mods but don’t think their shock tower will fit as the shocks mount to the gear housing on the tg10.
Steering. Wow it’s sloppy. Eventually I found the now extinct Tamiya alu steering hop up 53365. From a shop I’d not used before https://www.e-kalfakis.gr/ seem to have a few old parts. (Also got lightweight flywheel 53208 from them) Made a lot of difference. Especially when added to gpm wild dagger knuckles and c-hubs. Added some new alloy 12mm hexes and shimmed the whole front end, wheels (0.5mm), c-hubs (2x 0.1mm each side) and kingpins (.2mm) and it’s all much tighter.
finally added TR15 uprated brake disc 53171, stripped the engine and cleaned with old nitro fuel and a toothbrush.
performance wise not much I can do I think as so much no longer available. Really wanted the alloy brake arm but can’t find it anywhere.
injora 270mm jk body on its way and then I’ll look at the wheels once the fit of that is sorted
some pics
Discs are the same?
So the body arrived.
have to say the quality of the Injora is very good. Really sturdy and great interior detail.
but- damaged in transit😟
However I did do some fiddling. This thing is heavy.
so I need some stiffer springs for the rear- any suggestions? 53281 tgx springs seem to be not available.
also I wonder about how much space there will be around the cooling head with this hard body. Might have to cut out the interior. Is the body likely to melt?
  • Confused 1
That’s a real shame, these are great bodies - I have the green one too. I then ordered a red one which has not arrived :(
The hard top and rear seats unscrew. There is quite a lot of material under the transmission tunnel which you may need to remove. I don’t know how it would stand up to a nitro engine though.
What are you going to do? Lop off the front arches and remodel the front end?
Sent it back and ordered another!
Once it arrives I’ll hack it up a bit. It is a lovely scale body for the money tbh I was very impressed. What chassis are you using yours with?
Hope you get your replacement soon, the wait always feels too long.
My body is on a GCM Racing Skeleton chassis. I don’t think I have managed to squeeze a single Tamiya part on to the build yet so might give it a Wild Willy driver.
Bit of a delay but I got the new shell.
it’s big. And heavy. Not sure I can really get it to sit low enough without serious modification. But I will try and run it as is and see how we go. I dremelled below the drivers seat to give room for the cooling head but I wanted to keep the interior at the moment as I may reuse the body on something more scale.
i drilled a little hole for the priming valve in the tank7BC9B9BA-BBFE-4C3A-ACD2-868957833F20.thumb.jpeg.d3031a9c2c9609edeaefeaf62cacf5cb.jpega little bit of space for the cooling head!
F516E988-BFB7-40C9-8CEF-B975B4221EE6.thumb.jpeg.ca27aac3435cee8bc3a506aa58565b41.jpegBut body still sits to high I think. 79E68EB2-409F-4374-A18D-87B6DCA36AFD.thumb.jpeg.6afc759af80f8e4265692f1aa10c8fe1.jpegextra weight requires replacing the springs in the 2 part injora 80mm dampers to stiff CVA ones. I also dremelled the flanges on the plastic bumpers at the underside to allow front and rear arms a few mm of extra travel.
Not bad travel for a TG10.....
added 20mm hex spacers and some slightly larger beadlocks.
exra width makes a difference as the body is 210mm wide. It is really more 1/8
bit of a Frankenstein but it has been fun
now to run it
I suspect performance will be c**p with all the weight from the body and wheels but tbh it won’t get run much. Just wanted to breath some life back into it 8B036135-EA1F-42F7-890D-490BFC3151DE.thumb.jpeg.9e70c9bdf052fcfed9ce6b09cdf9c3d6.jpeg
Managed to get some tb-01 e parts from JK-RC so fitted the damper stays and junfac 20mm wheel bolt extensions.
Done.
