stew_mac 326 Posted December 12, 2020 I went out the other weekend with a bigger pinion and a little more timing to try and get a 140mph pass.... unfortunately I was not so successful. 2 Share this post Link to post Share on other sites
Collin 1956 Posted December 12, 2020 Its not on the video, right? Did you vaporized the chassis or can you still use it? Share this post Link to post Share on other sites
stew_mac 326 Posted December 12, 2020 23 minutes ago, Collin said: Its not on the video, right? Did you vaporized the chassis or can you still use it? who knows.... maybe the youtube vid might show it, and then show the car and the damage. One will never know, unless they click on the link. Share this post Link to post Share on other sites
Collin 1956 Posted December 12, 2020 Man, I saw the video with 2 propper runs. Its not that I am satisfacted about rc takeoffs but I might become blind. Edit: 3Min20 found it. It was simply... way to fast for me : ) Edit2: Lucky you! Have made some worse crashes at much lower speed. Pretty rigide chassis you have. Share this post Link to post Share on other sites
stew_mac 326 Posted January 28, 2021 Little update. I rebuilt the car after it took off last time out. finally got a good quality battery in it now so I have power and volts for days. first test and I ran out of range. So new aerials on order and will be back out again soon. 3 Share this post Link to post Share on other sites
stew_mac 326 Posted February 25, 2021 Little change is pace. going to try some drag racing with the TRF. added some 35mm front and 45mm rears. Share this post Link to post Share on other sites
stew_mac 326 Posted March 7, 2021 New PB with the TRF461x on 3s 1 Share this post Link to post Share on other sites
speedy_w_beans 4272 Posted March 7, 2021 How are the belts holding up between the drag racing and these speed runs? Share this post Link to post Share on other sites
stew_mac 326 Posted March 7, 2021 1 hour ago, speedy_w_beans said: How are the belts holding up between the drag racing and these speed runs? Only speed runs at this stage. I want to reach 141mph before doing some drags. but the rear belt takes the most punishment and after a 128, 138 and 136mph pass it’s still looking good. Share this post Link to post Share on other sites
stew_mac 326 Posted April 18, 2021 New PB of 142mph on 3s. The little Tamiya has been running like a champ. 4 Share this post Link to post Share on other sites
wolfdogstinkus 1893 Posted April 20, 2021 On 4/18/2021 at 2:14 PM, stew_mac said: New PB of 142mph on 3s. The little Tamiya has been running like a champ. The sign says 60. (The street sign) I mean.. How do you see it when it's so far away??. I think I'd need binoculars,, or paint the front a different colour. I put a flag on my speed run car and I'm only aiming for 50.. maybe I should visit the opticians. Lol 1 Share this post Link to post Share on other sites
stew_mac 326 Posted April 22, 2021 On 4/20/2021 at 5:16 PM, wolfdogstinkus said: The sign says 60. (The street sign) I mean.. How do you see it when it's so far away??. I think I'd need binoculars,, or paint the front a different colour. I put a flag on my speed run car and I'm only aiming for 50.. maybe I should visit the opticians. Lol It’s just a technique. I didn’t always run such a distance I worked up to it. But realistically you are following a spec on the horizon. If it’s warm enough the car will get lost in the haze on the road. Share this post Link to post Share on other sites
stew_mac 326 Posted June 13, 2021 New PB. 144mph with 3s in parallel. 4 Share this post Link to post Share on other sites
Aerobert 2145 Posted June 13, 2021 10 hours ago, stew_mac said: 144mph with 3s in parallel. That is crazy fast. My 1:1 car can't go that speed. Share this post Link to post Share on other sites
Nikko85 3453 Posted June 15, 2021 On 6/13/2021 at 8:24 PM, Aerobert said: That is crazy fast. My 1:1 car can't go that speed. I think most 1:1 cars might struggle.. Share this post Link to post Share on other sites
stew_mac 326 Posted August 15, 2021 Nee PB for the TRF on 3s. 1 Share this post Link to post Share on other sites
Superluminal 3750 Posted August 15, 2021 What do you think it will take to squeeze it up to 150mph? I cant watch the videos on my phone - are you topping out the gearing or running out of road? Share this post Link to post Share on other sites
stew_mac 326 Posted August 15, 2021 4 minutes ago, Superluminal said: What do you think it will take to squeeze it up to 150mph? I cant watch the videos on my phone - are you topping out the gearing or running out of road? I’m not 100% sure this motor will get that extra couple of mph. The last gear change dropped the rpm from 65,000 to 58,000. So it’s really impacting the motors power now. also the esc stops recording amps over 376 so I’m not sure how much more I’m demanding from the motor. the road in plenty long enough. Just not sure the motor has the legs for it. I have looked into a custom motor, and will also need a custom spur gear or 2. 1 Share this post Link to post Share on other sites
Collin 1956 Posted August 16, 2021 If your looking for the last very bit, try other clips. the one you are using making little air turbulences.... Share this post Link to post Share on other sites
stew_mac 326 Posted October 31, 2021 Made another pass today. unfortunately a motor wire unsoldered so I couldn’t return the car so the speed doesn’t count. Share this post Link to post Share on other sites
Collin 1956 Posted October 31, 2021 60k rpm with 6hp. Insane. 1 Share this post Link to post Share on other sites
stew_mac 326 Posted November 7, 2021 Video from the 152mph pass 1 Share this post Link to post Share on other sites
stew_mac 326 Posted February 20, 2022 First test pass with the new TP power motor. Just a little pass only just slightly touching 100% power out. 1 Share this post Link to post Share on other sites
stew_mac 326 Posted March 21, 2022 The new combo worked well. Hopefully will be back out soon to improve on my PB. Share this post Link to post Share on other sites
