Busdriver
window masks
A little tip, whenever you start an NIB build photocopy/scan the window masks. That way if you have to redo something after you have taken the originals off you can cut a new set from masking sheet.
Or if you don't have masks, I photocopy the window stickers and lay tissue-double sided tape over the paper. Trim & apply like masks... it holds up long enough for a quick rattlecan paint job.
Good tip, I have a method too: cut and apply the masks then keep the backing to template more as required.
