Gazzalene
Bearings, rubber or metal?
Being new to the hobby I have been buying Metal shielded bearing thinking metal must be better than rubber BUT am surprised the amount of time people suggest rubber shielded bearings
Is there a reason to choose one over the other? Where to use perhaps?
Rubber better suited to off roaders etc that get really wet. I have to say I dont know if theres buch benefit for internal bearings sugh as gearboxes etc? but drive shafts uprights etc their good. I tend to use rubber jut in case. My Stadim Thunder was running through puddles etc to day so worth it. Same price I think, at least they are from rcbearings.co.uk
If I recall correctly, both versions have their own advantages.
Metal bearings have a gap between sideplate and rotating part, giving them lower drag compared to rubber seal.
Rubber seals are better at keeping dirt out of the bearing compared to metal
For my konghead, I intend to do a mixed setup. Metal for anything inside a gearbox as this is sealed anyway. And rubber for the driveshafts at wheel side.
On a side note, I suggest you buy lots of bearings.  They are cheap and you can never have too many...
Terry
Image result for fletch ball bearings
There are also some bearings around nowadays, which have a metal shielded side and a rubber sealed side. They are intended for racing, to get the protection and the lowest possible resistance. Quite nice for wet races.:)
I buy cheap rubber shields ($3 for ten).  Anywhere it's exposed to outside air, I use them.
The rubber shield makes tight contact outside race. There is tiny gap with the inside race. There is some drag.  Metal shields, however, cannot make contact either races. If it did, the bearing won't turn.  So there are larger gaps. Tamiya uses thick grease to block the gap.  Below is how much I could scoop out from.  It's from 1 side after taking off the metal shield (from one 1150 bearing).
You can wash out this grease and use thinner oil.  But if you used that in dirt, it'd become gritty.  That's bad.
Which is why I use naked ball bearings only in the gearbox. (I seal the gearbox with plumber's grease to make it almost waterproof)  If there is no dust, no shield is fine.
These naked bearings spin as easily as fidget spinner bearings.
When it has absolutely no oil and no grease, it even works like a ceramic bearing. (But that's bad)  You can stick a 5mm shaft and turn it, it literally turns for 60 seconds.  But no oil means the bearing will wear out really fast.  So I use light machine oil.  If I didn't, as bearings wear down, pinion gear will push spur gear farther, and gears would wear too.  If you remove grease, light oil is a must.
Is it worth going through all this trouble?   For the most part, No.
Why bother doing this for a simpler car like the Hornet?  It has only 3 gears.  As long as it's got those 13 bearings, it should be fine.
But Konghead and Dynahead use 40 to 70 bearings.  For these, some bearing-planning could pay off.  Small friction on each bearing adds up 70 times.
With 18 "naked" bearings on the inside, my fingers can turn one drive cup. All 6 drive cups would turn for almost 1 second (with diff clay). That sounds like nothing.  But with this many gears, + grease on the teeth, 1 second is a lot.  (I use Labelle 106 Teflon grease -above- to reduce friction between teeth too)
Rubber shields are easier to remove.  I take the shields off and re-lube them for the internal gears.  I leave shields for outside.
Everybody is different.  But for me, this made the most Vulcan bearing logic.
(For younger folks, this guy would make more sense)
Man, for 90% of general RC use, rubber shielded is the way to go. Yeah, metal shields can have less friction, and so can Teflon, but I'm not willing to do the extra maintenance on a runner, especially if it's one that gets run hard frequently. Now, on a stock class race car, I can see the benefits of bearing tricks.
