Having owned a Clodbuster on two separate ocassions, I came to the conclusion that what really attracted me to it, was it’s body...so I decided to build a truck around the body....😁
So I started with a pair of SCX10 chassis rails and aluminum shock mounts.
Not wanting to use wideners on stock SCX10 axles, I went with a set of EBay aluminum Wraith axles, metal drive shafts and an SCX10 Transmission.
The suspension links were made using brass and aluminum standoffs, that were meant to be used as mocking links, but I like the way they looked, so I made them all like that.....
I went with a lift kit and 100mm RC4WD King Shocks.
The Body is being held in place with a set of earth magnets up front, and will be held in place with a magnetic stealth wireless mount😉
Looks good! Do you like those Ranger tires? How do they compare to Monster Beetle/Blackfoot size-wise? This is more realistic than Kyosho's attempt ;).
I ran them on my other monster truck, and they’re great....size wise, they’re way bigger than Blackfoot/monster beetle tires....Proline makes the 2.2 destroyers, that are a tiny bit smaller than the rangers, but I thing they’re still way to big for the Blackfoot/Beetle.
If you get the Midwest wheels and space it properly, you might be able to make them fit on the ORV👍
Thanks. I don't think I'll be using them on a Blackfoot though, just using that as a size comparison because I know how big Foot/Beetle tires are.
I think they’re good looking tires👍
30 minutes ago, 87lc2 said:
Nice trucks.  Have to get a set of those Golden Years at some point they look great.  Is the Ford Axial based as well?
Thanks,
Yes, they are awesome looking tires....😁
Yes, they’re both SCX10 based😁
Progress,
Started mounting the seats and driver, the driver is the Marvel Legends Ego figure, I found that these work very well with these smaller bodies.
The seats are from an RC4wd Blazer interior that I’d hope it would somewhat fit, but it’s too bulky, I ended cutting it up and using only the seats and part of the dash, basically the part where the steering wheel mounts...
5 hours ago, tecnica2001 said:
He does look like Jeff Bridges, but it’s Kurt Russell😂
Kurt Russell /Jeff Bridges awesome either way :lol: (will read IMDb 1st next time!) thanks for setting things straight @tecnica2001 ;)
