svenb 3735 Posted December 27, 2019 Anyone know if the tt01e has a stabilizer set or can the regular tt01 53694 fit? Or any other chassis specific set that could be used. Thanks Share this post Link to post Share on other sites
TurnipJF 9111 Posted December 27, 2019 53694 is designed to mount to the carbon upper deck P/N 53672, which fits the TT-01E in place of the stock plastic one, but necessitates a different steering rack / rack attachment method that doesn't bolt through the upper deck - I would suggest a ballraced one from yeah Racing, GPM or similar if you want to go this route. Share this post Link to post Share on other sites
Superluminal 3729 Posted December 27, 2019 I bought a front and rear set of these recently thinking I could use them on my TT01E - seems like you need to spend as much again as a whole new kit on all the bits to get it to work (aactually possibly a lot more as the TT01 chassis brace is like hens teeth) Share this post Link to post Share on other sites
TurnipJF 9111 Posted December 27, 2019 I wonder if it would be worth sending the measurements of the Tamiya 53672 off to Fibrelyte and getting them to cut you one? You could even add refinements like a transponder mount and bolt-through points for the TT-01E steering rack. 2 Share this post Link to post Share on other sites
Superluminal 3729 Posted December 27, 2019 Thats a very good shout. Its only in the last couple of days here I discovered they do one for the TT02. It may need some some spacers experimenying with as the stabilizer bars are secured by an aluminium block that clamps to the top of the gear box in the tamiya chassis brace kit Share this post Link to post Share on other sites
AndyForbes 63 Posted December 27, 2019 You need 2x TT01 front sets (or only 1 front set if you are running different coloured stabilizers at each end) Check out the TT01R Type E manual - page 18 will show you what you need, and how to install it all. https://www.tamiya.com/english/rc/manuals.htm 1 Share this post Link to post Share on other sites
Superluminal 3729 Posted December 28, 2019 Do you have a scan / pic of this page? The manuals in the download are for just the standard TT01-E chassis (even the one for the supposed Type R) Share this post Link to post Share on other sites
ACCEL 2014 Posted December 28, 2019 RCMart and Asiatees had everything i could hop up with and when doing the TT01E Buggyra (FAT FOX GULF) i do not remember all the parts, but yes i surpassed way beyond standard kit costs, i always get caught up in the moment. It's too much fun Share this post Link to post Share on other sites
martinjpayne 273 Posted December 29, 2019 @Superluminal scroll down to page 18: OPTIONS https://www.tamiya.com/english/rc/rcmanual/58450tt01r_e.pdf 1 Share this post Link to post Share on other sites
Superluminal 3729 Posted December 29, 2019 Hmmm, looks like the type-e R has completely different lower arms and bumper mounts to the standard type-e. Share this post Link to post Share on other sites
martinjpayne 273 Posted December 29, 2019 Yes, looks like they're from the TT-01D. Part number 51217. Share this post Link to post Share on other sites
svenb 3735 Posted December 31, 2019 On 12/27/2019 at 8:03 PM, TurnipJF said: 53694 is designed to mount to the carbon upper deck P/N 53672, which fits the TT-01E in place of the stock plastic one, but necessitates a different steering rack / rack attachment method that doesn't bolt through the upper deck - I would suggest a ballraced one from yeah Racing, GPM or similar if you want to go this route. 🤔 If I were to use the 53672 carbon Upper deck on a tt01e does that mean I need the regular 01 steering set up? As far as I can make out the 01e is exactly the same as the 01 except for the steering arms bolting through the plastic upper deck! Share this post Link to post Share on other sites
TurnipJF 9111 Posted December 31, 2019 Just now, svenb said: 🤔 If I were to use the 53672 carbon Upper deck on a tt01e does that mean I need the regular 01 steering set up? As far as I can make out the 01e is exactly the same as the 01 except for the steering arms bolting through the plastic upper deck! You could use the stock '01 steering setup, but a ballraced alloy upgrade would be much better - the sloppy stock rack was one of the weak points on the standard '01. 1 Share this post Link to post Share on other sites
svenb 3735 Posted December 31, 2019 (edited) I have a carbon Upper deck and fancy the 01 stabilizer set up so it should just be a case of swapping the 01e steering for the 01!? I think I'll need different steering posts too. Thinking about it 🤔 I keep the e steering set up and just replace the posts with sleeves and screws 👍 Edited December 31, 2019 by svenb Share this post Link to post Share on other sites
