Graham J 3 Posted December 30, 2019 I have a vintage Avante restored with it’s original Adspec remote. The steering servo works fine. The motor kicks when the battery is connected. I can also get the wheels driving forward at speed using the TH trim adjuster. I can get 5-6 volts to the motor doing this. I can also get 2 volts in reverse using the trim adjuster. The throttle trigger will however not give me any voltage or turn the motor in either direction. Any advise would be appreciated..... Share this post Link to post Share on other sites
ddaenen1 278 Posted January 22, 2020 On 12/30/2019 at 1:17 AM, Graham J said: I have a vintage Avante restored with it’s original Adspec remote. The steering servo works fine. The motor kicks when the battery is connected. I can also get the wheels driving forward at speed using the TH trim adjuster. I can get 5-6 volts to the motor doing this. I can also get 2 volts in reverse using the trim adjuster. The throttle trigger will however not give me any voltage or turn the motor in either direction. Any advise would be appreciated..... Have you checked the receiver output, e.g., if the steering servo works fine, have you switched the steering servo connection and the ESC connection on the receiver around? To determine if it is in the TX/RX area or the ESC? Share this post Link to post Share on other sites
Graham J 3 Posted January 22, 2020 All sorted now thanks. Stiff potentiometer on transmitter. Share this post Link to post Share on other sites
