So I got this kit last November and decided to convert it into a proper 4WD rally car since I already have an FF rally car.
Here is the stock car when it arrived.
Box stock have these:
-carbon reinforced main tub chassis
-all metal gears including differential planetary
-full ball bearing except for steering. All bearing are same size of Tamiya
-aluminum adjustable motor mount
-Aluminum center shaft
-aluminum chassis posts
-aluminum suspension blocks
-universal front shafts
-steel rear dog bone shaft
-steel outdrive cups (front and rear)
-60mm big bore aluminum dampers (hard springs)
-mounted tires on wheels
-urethane bumper
-waterproof casing for electronics
As the title says "underrated", I decided to give this kit some improvements.
Here are the modification and changes:
-replaced stock bushing of steering to 850 size bearings
-changed the ball studs and ball cap ends to Tamiya
-all aluminum (blue) turnbuckles (upper suspension and steering)
-fabricated top deck from 3mm carbon fiber board (DIY cutting and drilling using Dremel)
-fabricated battery holder from 3mm carbon fiber board (DIY cutting and drilling using Dremel)
-rebuild both diffs as they have binding and replaced lubrication with 200k oil front, and 20k oil rear.
-replaced stock 60mm shock with YR 60mm Shock Gear and replaced shaft end to extend another 5mm
-aluminum front knuckles and C-Hubs (both ZD Racing). No more lose play.
-replaced rear body post to Tamiya (extra frm my FF) to accommodate hatch bodies)
-Replaced plastic hex hubs to aluminum (ZD Racing)
-replaced stock servo mount to aluminum (ZD Racing)
Here it is now.
with my friend's stock S10
The Tamiya ball studs and ball caps have made such big improvements from the stock ones. Steering bearings also made it better. The cf top deck reduced chassis flexing by 80-85% because the stock plastic top deck was too flexible. The dampers have also played a big part in rallying set up.
I have built two Tamiya TT-02 kits for my cousins, one for on-road and another one converted to rally, Both have slightly been upgraded. In my opinion and observation, I should say that the S10 is so much better than the TT-02 kits  in terms of sturdiness and build. Performance wise, it's stable and very responsive after the modifications*.. A lot cheaper too.
My modified S10 only costs total of $130 (excluding electronics).
Does the S10 have the ability to have front body mounts “above the shock tower” like is standard on TT and TL chassis? I need a chassis for an already drilled Tamiya body
**Edit - and where are they available?
Body mounts on the shock tower can be customized using Tamiya body posts. Check the LRP site here:
https://www.lrp.cc/en/product/s10-blast-tc-2-clubracer-non-rtr-no-wheels-and-body-110-4wd-electric-touring-car/
But I got mine from an Asian version of "Amazon" called Lazada.
  • 3 months later...
Some updates.
The S10 comes with 2 planetary gears for the diff instead of 3 or 4. I have tried using 30k diff oil but it just doesn't work for the front. So instead, while waiting for the lockdown to end, I thought of locking the diff with a sticky tack and it worked.
Installed the Rocket fan. This is probably the strongest motor/ESC fan and it only cost $10. Rated at 28000rpm and has aluminum casing too. Shortened the ESC-to-motor wires and installed bullet connectors.
With the right set up, this car is truly amazing and can perform well.
  • 9 months later...
On 2/16/2021 at 1:00 AM, maryn said:
wich diff did you locked?
i just got a second hand blast tc and only the rear diff is locked and i dont know why
The front diff. Front and rear diff are the same. You can move the rear to the front. Try to open up the diff and see what the previous owner used for locking.
  • 2 years later...
@Nicadraus, always admire your wiring work; where do you obtain the wire clamp organiser things and what are they called? I've searched for all sorts of terms but can't find what you have on many of your builds.
  https://www.rcmart.com/Wire-Plug-Connector/Wire-Plug-AND-Connector-Wire-Guard-Clamp
3 hours ago, Busdriver said:
Google RC wire clamp!!! YR make a version but there are others
@ChrisRx718 ^This. There are several available at RCMart. Bought a couple different ones and also used one to hold the brake cables of my bike.
