rwordenjr
DT03 motor suggestions
4 hours ago, rwordenjr said:
What’s the best shock oil for the dt03?
Depends on the pistons you are using. I converted my dampers to use the plastic pistons on the shock parts trees. I use 1 hole pistons with 500cst rear and 600 front. If you still have the all metal fixed plate piston/rods from the kit i would recommend getting something like 800cst oil. I use core rc shock oil, simply because its easy to get and good value (bigger bottle than tamiya oil).
Thanks TDC, I'll check those out! The stock oil on the black edition is pretty stiff
