Picked this bargain up on gumtree last week
it’s from the 90s I believe
Came with box, instructions, transmitter, MSC, battery and charger
its in excellent condition and has hardly been run at all
so why is this a build thread??
well the paint is shocking tbh
it’s been painted with a brush and the paint applied v thickly
so it’s time to redo the shell
I have some unused stickers in the box
so I started to strip the shell using the bbq cleaner from b&q
liberal application and wrapped in a plastic bag
took about 3 applications and still left some bits
the rest I will attach with some paint remover
just working out a plan for paint now
JJ
Interesting arrangement with the steering servo - I wonder if that is why it has hardly been used? I'd guess it wouldn't turn very well set up like that...
Yeah I think something has failed tbh
its on my list to look at :)
either servo is stripped or It’s just incorrectly assembled
it’s defo not “connected” though
JJ
thw servo had no saver on it and the horn was upside down - no idea why tbh.
fixed though now
I am missing a battery stay (part A3) so looking for parts without having to buy the £12 parts tree :(
JJ
And now in the process of working through a bodywork design now it’s stripped
so lightly primed in white etching primer
plan is for an orange stripe down the middle and matte black
orange laid down..
but obviously just doing a stripe is too easy
so I masked off the whole car so just the stripe was showing and hydro dipped it
desired effect achieved
once its dried I will mask off the stripe and paint the rest of the car matte black and potentially apply some of the remaining stickers
JJ
So laid done the black yesterday
masked up almost everything but tried to create orange accents where possible
scary to peel off the masking tape to see if the Hydro dipped pattern stayed
but it did...
and apart from some minor overspray it looks great
JJ
  • Like 10
Looks great , just needs some better wheels to go with it.
just out of interest how did you hydro drop that effect? I’d like to experiment with this sort of thing in the future
Hydro dipping is easy
i just masked off where I don’t want the film to stick (same as painting)
Cut out film
tape edges
lay on 34 degC water
apply activator spray and leave for 1min
pass item through at 45deg angle
mJNTBSX.mp4
2SYEAKI.mp4
this is how I masked up the grasshopper 2
result
None of the stickers actually go with the car now (there were only a few left over) so finishing touch...
got some orange dye on way and I’ll do the wheels and see what they come out like
JJ
That is pretty cool. IF you use it much it will improve massively with shocks. Also worth doing the steering mod as its woo full.
Here is my daughters, I just got a sheet of red vinyl and cut some stick on stripes to lay over the baby pink.
2019-10-12_07-06-32
2019-10-12_07-06-32
Very cool :)
mine are primarily shelf ware :)
I need a battery stay before I can drive it anyway
JJ
32 minutes ago, Problemchild said:
Very cool :)
JJ
I made one from another bit of unused parts tree, its a flip version so I can change the battery faster, no r clip to lose or pull out with numb fingers will see if I can get you a photo (use anything hat works)
