The Twingo Lord 31 Posted February 12, 2020 Is it possible to power 2 low power ESCs with one battery. I’m using a Tamiya dual motor gearbox to make a car with tank steering for a school project. Share this post Link to post Share on other sites
Busdriver 6207 Posted February 12, 2020 I've done it in boats loads of times. It allows you to Tank steer a boat by using Rudder and Aileron channels on a 4 channel set. If you have mixing on your set you can do a whole load of things. You need a y lead made up. Maybe get less run time etc though. Be careful how you connect to the reciever as you in effect have two BEC circuits feeding in to the receiver. You can disable one of them by removing one wire from the plug but for the life of me I cant remember which Share this post Link to post Share on other sites
Hobgoblin 1059 Posted February 12, 2020 Yes! This is how I built my first robots many moons ago (with tamiya dual gearbox) and I still use a lot of twin escs to power tank drive robots and rc platforms from 75g to 110kg. It all works the same in principle. You will just need either a 2 into 1 plug adaptor or to solder the power in wires together. You will need to remove, either unplugging or clipping the red wire from one ESC so you don't risk your RX. Be warned, most RC car escs are unsuitable because of the non instant reverse, lower powered reverse rate and brake delay. Crawler ESCs do not have this issue. Share this post Link to post Share on other sites
The Twingo Lord 31 Posted February 12, 2020 1 hour ago, Hobgoblin said: Yes! This is how I built my first robots many moons ago (with tamiya dual gearbox) and I still use a lot of twin escs to power tank drive robots and rc platforms from 75g to 110kg. It all works the same in principle. You will just need either a 2 into 1 plug adaptor or to solder the power in wires together. You will need to remove, either unplugging or clipping the red wire from one ESC so you don't risk your RX. Be warned, most RC car escs are unsuitable because of the non instant reverse, lower powered reverse rate and brake delay. Crawler ESCs do not have this issue. Do you know of any cheap crawler ESCs? Share this post Link to post Share on other sites
Otis311 187 Posted February 12, 2020 Hobbywing Quicrun 1060 has the ability to go directly to reverse with no brakes. 2 Share this post Link to post Share on other sites
Hobgoblin 1059 Posted February 12, 2020 https://hobbyking.com/en_us/hobbyking-x-car-45a-brushed-car-esc.html?queryID=b0057bfab365b217b57faf8abd9b0fce&objectID=48605&indexName=hbk_live_magento_en_us_products Will work with programming, as will the 1060. However, if you are only using small motors (130) why waste big and bulky escs? https://www.ebay.co.uk/itm/223787562024 I have ordered a few of these to test out for small robots, I'll double check they tick all the boxes. 1 Share this post Link to post Share on other sites
WillyChang 1812 Posted February 12, 2020 You could also recycle the circuit board out of servos... they're pretty much an ESC if you disconnect the pot. Better still just use the whole servo (lookup "360 mod") & you'll get a motor & gearbox too lots of mini skidsteers built from 2 servos. 2 Share this post Link to post Share on other sites
Busdriver 6207 Posted February 12, 2020 Deans Marine a model boat company makes a series of model boats that use servos in place of esc and motors. There is a kind of Tutorial on their site how to do it Share this post Link to post Share on other sites
