Nutloaf 1 Posted February 25, 2020 Hi, I know frog and monster beetle share same basic chassis, does anyone know if mb front shock towers can fit on a frog? (Putting aside the frog body shell might need to be modified) Share this post Link to post Share on other sites
slimleeroy 241 Posted February 25, 2020 It will do yes but will look shockingly bad. The monster beetle also uses different wishbones and uprights 1 Share this post Link to post Share on other sites
Mokei Kagaku 2706 Posted February 25, 2020 18 minutes ago, slimleeroy said: It will do yes but will look shockingly bad. The monster beetle also uses different wishbones and uprights I agree that it will look pretty bad as the MB front tower is so high. Also, without the cover behind it, it will flex quite a lot. You are better off getting an aftermarket front shock tower made for the Frog and use “Mini” size dampers instead of “Short” size dampers as on the MB. And yes, the uprights are different, but the MB wishbones are actually the same as the Frog wishbones. However, the upper/inner stepscrews for the wishbones are a little longer than on the Frog because they double as shock tower mounts (and to fix the servo saver “reinforcer” on the original release MB). 1 Share this post Link to post Share on other sites
tacomancini 11 Posted February 25, 2020 I’m doing a front Monoshock thing right now, but if If I was going for dual front independent shocks I’d opt for the Ampro solution that can be bought in shapeways. It seems like it is the most frog-like while supporting modern shocks. I like how low profile it is but it also extends the wheel base a little. However you do lose caster adjustment. 1 Share this post Link to post Share on other sites
KEV THE REV 2304 Posted February 25, 2020 I used stock CRP towers and CRP dampers and kept the original springs in the chassis for this runner , nice and cheap . I might remove the springs and convert the dampers to coilovers at some point like the one shown above by Tacomancini 4 Share this post Link to post Share on other sites
Frog Jumper 3605 Posted February 26, 2020 There are a few 3D printed solutions on Shapeways. CRP also made a set (#9114). I recommend the alloy JunFac mounts (or similar). I do NOT recommend the aluminum horseshoe shaped one-piece mount available on eBay. It’s bends too easily. The Tamiya CVA shocks #50519 fit and perform well, considering it’s still a Frog... https://jpegbay.com/gallery/007550055-.html#1 Terry 1 Share this post Link to post Share on other sites
Frog Jumper 3605 Posted February 26, 2020 Also, if you use the Frog metal uprights, you can drill out the small unused hole with a 5/64” bit and needle file to get to the 2mm you need for a typical screw... Terry Share this post Link to post Share on other sites
Frog Jumper 3605 Posted February 26, 2020 9 minutes ago, Frog Jumper said: Also, if you use the Frog metal uprights, you can drill out the small unused hole with a 5/64” bit and needle file to get to the 2mm you need for a typical screw... Terry It might be 5/32 and a 4mm hole... too many years and too many beers... Terry Share this post Link to post Share on other sites
FoxShot 280 Posted February 26, 2020 7 hours ago, Frog Jumper said: It might be 5/32 and a 4mm hole... too many years and too many beers... Terry Lol. You yanks are funny with all your imperial measurements. Why nit just get a metric drill bit set! 1 Share this post Link to post Share on other sites
StueyS 41 Posted February 26, 2020 This is my Frog with a front shock conversion. I have not had chance to try it yet, but it should work a lot better than the kit setup. 2 Share this post Link to post Share on other sites
Nutloaf 1 Posted February 26, 2020 StueyS your Frog looks really cool. Well done. What shocks / shock tower is that? 1 Share this post Link to post Share on other sites
StueyS 41 Posted February 27, 2020 Thanks. The front towers are the alloy ones on eBay, and Tamiya CVA 50519 on the front set to 70mm. The rear shocks are Trackstar and green Team Associated springs. 1 Share this post Link to post Share on other sites
Nutloaf 1 Posted March 24, 2020 Good stuff? Are they Dyna Storm / Astute wheels? Share this post Link to post Share on other sites
StueyS 41 Posted March 24, 2020 The front wheels are Tamiya ones (not sure which ones?) and the rear are Kyosho Turbo Scorpion. Share this post Link to post Share on other sites
Nutloaf 1 Posted March 25, 2020 Thanks StueyS, were the Rear Wheels a straight fit on the Frog or did you use some adapters? Share this post Link to post Share on other sites
StueyS 41 Posted March 25, 2020 I have fitted the Tamiya Frog hex adaptors. Share this post Link to post Share on other sites
