Those 80´s toy grade cars  have 6 functions control (7 functions including Stop).
Here is a Nikko car with those functions:  http://reparar-cochesrc.blogspot.com/2015/12/emisora-nikko-de-6-funciones-y.html
Nikko used a square signal (50% duty cycle) for "forward - 350Hz" and "backward - 900Hz".
On the "right" side it was 75% duty cycle and on the "left" it was 25% duty cycle.
Taiyo used the same signal and frequencies but forward and backward were swapped.
Other manufacturers used other I.C's decoders but the control signal was the same (the square signal frequencies could be different).
Some of these i.c.´s are:
TA7657
T8140
 finally  found a photo. But if the model is  full function type, why is there a potentiometer on the steering? Usually, at least in the small models, the neutral position is obtained with a spring and no signal in the steering motor. It looks like a servo.
It´s a semi-proportional control car. The steering is proportional control and a single speed to go forward or backward.
SN76604 i.c. was widely used the for steering control.
