Hey everyone,
As I've been stuck in my flat since new year's eve due to my health and now this Corona BS I've got a million projects on the go. My next one is a Lowrider with functional air suspension.
I've started with a TA02SW kit but I'm making a custom top and lower deck using 3mm styrene sheet. This will be more of a shelf queen so that should do, although I might later get a custom deck made from carbon fibre sheeting. The 1st step was to mark where all the holes are and then move the front section 54mm to get the wheelbase I need for the F350 body.
32 minutes ago, speedy_w_beans said:
Very interested in your air suspension...
The system I'm using is from a guy in Canada which is actually designed for 1/14 trucks. The front and rear wil; be adjusted independently
received_632080830912467.thumb.jpeg.5896f046c8f7430efcce675bfc518bbb.jpegreceived_200201504370123.thumb.jpeg.443a836a43e0b4263e5deae441622fc1.jpegreceived_1075946299425334.thumb.jpeg.620db9ae9964f7cab95ab3ffa94c77eb.jpeg
The chassis is taking shape. Need to cut the rear shock tower down but everything seems to line up. I've made it wider so I can use the original mounts for the front body and for extra room for the extra electronics
20200328_191955_compress65.thumb.jpg.2681edb0a6c087b9ef8009c3366654ce.jpg20200328_191829_compress77.thumb.jpg.c07cf91567818ca37411ed029229821c.jpg
